OK so I decided to clean my 6800 ultra. I took the heat sink and fan off and re applied AS5 to the GPU. My ram on the ultra had white pads that seemed to sit inbetween the HS and ram.
If I where to replace the white pads with a little bit of AS5 would I run into problems? I know AS5 is conductive due to the silver in it, do I pose any problems having it directly on top of the ram chip then touching the HS?
let me know since I have it appart now hehe.
