I would imagine so. However, for a true answer you should contact arctic cooling directly for compatibility. According to arcticcooling.com it is designed for the 7800 series, however sometimes the mounts and placement of memory modules and such are similar for similar cards.
Yes, sort of..You need to chop off a portion on the exhaust end of the cooler (the plastic part)..Try searching threads from the past, you should come up with something with pics.
[edit] Found the thread I was thinking of - 3 pics worth here .
