ok so I bought a artic cooling liquid freezer 120 for my I7 3770k. I had air cooling prior and in bios would show about 45c for the cpu. in Windows cores would go over 100c when full prime 95 which is why I decided to put on new thermal compound and a new cooler.
so I swapped everything out and put the new gelid thermal compound on the cpu then attached the water cooler put everything back powered up pc went straight into bios expecting to see lower than 46 but instead was greeted with 88c and it was climbing about. 5 degrees every second or 2. I powerd down tightened screws with a screw driver instead of just thumb tight and still same results. took it off reapplied paste and used a lot more this time since last time I went light thinking might help but still no go.
fan spins on the radiator but how do I know if the radiator pump is pumping?
is this a sign of a bad pump? radiator is never hot to the touch.
would the pump not working cause Temps to go that high right as soon as you start the pc? or does that sound more like it's not making good Co tact or something?
any help would be awesome
