Artefact (5.2 catalyst) is it the driver ?
stevenj
With my LCD , a viewsonic vp201s, I got some artefacts (blue flickering on black before windows load and sometimes in windows + games) Do you think was the driver or the driver settings ? Vsync, should I enabled ? and the other settings on catalyst 5.2 ? could you help me about that ? Thanks
If you get it before windows loads, it isn't the driver. My guess would be a couple of dead pixels, or maybe a memory chip on the video card itself is going bad.
Dead pixels ? I checked with some program and zero dead pixel. And I try with another monitor (CRT) and was okay...so is it the DVI cable ?
It could be, at least you ruled out the card, monitor, and drivers. Try cleaning the connectors?
