Arris SB6183 Cable Modem Possible Overheating: Comcast Customer
Discussion in 'Networking & Security' started by biggles, Jan 1, 2018.
  1. biggles
    biggles [H]ard|Gawd
    1,754
    Jul 25, 2005
    Having intermittent internet connection issues. Comcast does not show outages in the San Jose area.
    After trying the obvious things like power cycling all networking devices, I noticed the cable modem was quite hot. So I unplugged this for about 10 minutes until it cooled off. Things have been running fine since yesterday. The SB6183 is about 1 year old.
    Is this likely to be a defective modem, or is there something else likely to be causing problems? Recommend replacing SB6183?
  2. Vengance_01
    Vengance_01 [H]ardness Supreme
    5,590
    Dec 23, 2001
    Log into your modem and post your stats. That should give you a better clue if its the modem or Comcast.
  3. biggles
    biggles [H]ard|Gawd
    1,754
    Jul 25, 2005
    Status
    The statuses listed show the connection state of the cable modem. They are used by your service provider to evaluate the operation of the cable modem.
    Startup Procedure
    Procedure
    Status Comment
    Acquire Downstream Channel Locked
    Connectivity State OK Operational
    Boot State OK Operational
    Configuration File OK
    Security Enabled BPI+
    DOCSIS Network Access Enabled Allowed
    Downstream Bonded Channels
    Channel
    Lock Status Modulation Channel ID Frequency Power SNR Corrected Uncorrectables
    1 Locked QAM256 10 573000000 Hz 7.3 dBmV 38.7 dB 20358 0
    2 Locked QAM256 1 513000000 Hz 8.2 dBmV 39.3 dB 8679 0
    3 Locked QAM256 3 525000000 Hz 8.3 dBmV 39.3 dB 9650 0
    4 Locked QAM256 4 531000000 Hz 8.4 dBmV 39.2 dB 11953 0
    5 Locked QAM256 6 549000000 Hz 8.2 dBmV 39.0 dB 11765 0
    6 Locked QAM256 7 555000000 Hz 7.8 dBmV 38.9 dB 18296 0
    7 Locked QAM256 8 561000000 Hz 7.5 dBmV 38.8 dB 20072 0
    8 Locked QAM256 11 579000000 Hz 7.3 dBmV 38.7 dB 22180 0
    9 Locked QAM256 12 585000000 Hz 7.3 dBmV 38.6 dB 21718 0
    10 Locked QAM256 13 591000000 Hz 6.9 dBmV 38.3 dB 23828 0
    11 Locked QAM256 14 597000000 Hz 6.7 dBmV 38.3 dB 24440 0
    12 Locked QAM256 15 603000000 Hz 6.6 dBmV 36.9 dB 48019 0
    13 Locked QAM256 16 609000000 Hz 6.3 dBmV 37.2 dB 34920 0
    14 Locked QAM256 18 621000000 Hz 6.1 dBmV 37.8 dB 30493 0
    15 Locked QAM256 29 681000000 Hz 3.8 dBmV 32.1 dB 229979 0
    16 Locked QAM256 25 687000000 Hz 3.8 dBmV 34.7 dB 142974 0
    Upstream Bonded Channels
    Channel
    Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
    1 Locked ATDMA 13 5120 Ksym/sec 19300000 Hz 40.3 dBmV
    2 Locked ATDMA 14 5120 Ksym/sec 25700000 Hz 41.5 dBmV
    3 Locked ATDMA 15 5120 Ksym/sec 32300000 Hz 41.8 dBmV
    4 Locked ATDMA 16 5120 Ksym/sec 38700000 Hz 42.8 dBmV
  4. Vengance_01
    5,590
    Dec 23, 2001
    Those are not bad at all. In the event logs(on the cable modem) do you notice around the time of the issue any errors?
  5. Ehren8879
    Ehren8879 Little Bitch 3
    4,256
    Sep 24, 2004
    go to the "event log"
  6. Kelter
    Kelter Limp Gawd
    340
    Dec 23, 2005
    I'm in San Jose as well with Comcast, and haven't noticed any drops. So, at least somewhere upstream at Comcast, things are ok... doesn't mean your particular area is without issue though.
    Might want to try running a basic ping test from your computer to your router, modem, gateway of the modem (some Comcast node), and something on the internet.... depending where your ping fails when you have an incident, can help to identify where things are broken.
    If you can ping your router but not your modem when you have an issue, probably something wrong with your modem or connection between your router and modem. At that point, might be worth replacing the modem. If you cannot ping your router, then probably the modem is ok and the router is having issues. If you can ping your modem but not your modems gateway, then could be some issue with Comcast. This is a very simplified view of things, but might be a good start.
  7. biggles
    biggles [H]ard|Gawd
    1,754
    Jul 25, 2005
    Event Log
    The table below contains the log of events that the SB6183 has detected. This log can be important to the service provider to help diagnose and correct problems, if any should occur.
    Time Priority Description
    Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6
    Time Not Established Critical (3) No Ranging Response received - T3 time-out
    Mon Jan 01 01:17:38 2018 Critical (3) Resetting the cable modem due to docsDevResetNow
    Sun Dec 31 23:09:39 2017 Critical (3) Resetting the cable modem due to docsDevResetNow
  8. x509
    x509 [H]ard|Gawd
    1,618
    Sep 20, 2009
    I live a bit north of San Jose, and I have also had no drops that I noticed.
    I have a similar setup with an Arris cable modem. How can you ping the cable modem?
  9. GotNoRice
    GotNoRice [H]ardForum Junkie
    9,066
    Jul 11, 2001
    I doubt the 6183 is overheating. My 6183 lives in a small outdoor shack in direct sunlight that during the summer gets as hot inside as most closed-up cars do when parked in the direct sun. We had periods of 105F+ (exterior temp) during this last summer, yet the modem did fine. It's difficult to imagine a situation where it would overheat while indoors. You would be hard-pressed to find a more reliable modem than the 6183.
    The modem has a diagnostic webpage that can be accessed at http://192.168.100.1/ As a result, you can simply ping 192.168.100.1 if you want to ping the cablemodem.
    x509 likes this.
  10. Vengance_01
    5,590
    Dec 23, 2001
    You can also have dslreport ping your public ip which would be pinging your modem from the outside
  11. Kelter
    Kelter Limp Gawd
    340
    Dec 23, 2005
    From your error logs, the issue is definitely at the modem. Is it completely due to the modem? Maybe not though. From a google search on the error, the reset is issued remotely via SNMP for various reasons... being that yours is constantly resetting, I would imagine it is due to a connection sync issue or something similar.
    If you have a bunch of splitters or large splitters, remove or replace them to see if it helps the issue. Also, if you have a signal amplifier on the line, maybe remove it to see if it helps. If none of that helps, maybe it's time to replace the modem.
  12. codydeweyv2
    codydeweyv2 n00bie
    2
    Aug 1, 2015
    Check to make sure you are using the correct DC charger for it. I had accidently switched with my Router power cord, which was .5 amps less and caused the modem to drop ocassionally. Based on this Power levels list : http://arris.force.com/consumers/articles/General_FAQs/SB6183-Cable-Signal-Levels
    You are running in spec on your power levels for downstream, but you are under the recommended power for upstream. They say for upstream you want +51 DBmv to 45 DBmv. Looks like you are pushing 40-42. It may be worse when connection issues happen so check that page when it happens again. Call Comcast, they just need to attenuate your lines.
    Good Luck
  13. x509
    x509 [H]ard|Gawd
    1,618
    Sep 20, 2009
    Awesome! :love: :)
  14. SamirD
    SamirD [H]ard|Gawd
    1,714
    Mar 22, 2015
    If the problem is still occurring and you suspect it is because of heat, put a small fan blowing on the modem after unplugging it long enough to completely cool down. If it works fine after this, take the fan off and see if it starts having issues again. If so, then it definitely is your modem.
  15. heman22union
    heman22union n00bie
    40
    Nov 6, 2013
    You could try running a continuous ping from your computer to 8.8.8.8 You can also log the results to a text file for further review or historical comparison.
    Open command prompt and type in "ping 8.8.8.8 -t -l 1000 >ping.txt" without the "
    the -t makes it continuous
    the -l 1000 sets the packet size to 1000 bytes. That is a lower case L btw.
    > ping.txt just pipes the output to a text file called ping.txt. You should probably put the date on each file i.e. ping-2-13-2018.txt
    Do not close the command prompt as it will stop pinging.
    Let it run for 24 hours or even just 8 hours and do it a few times changing the file name each time. At the end of the text file, there is a summary of the findings. This will test your modem and router.
    When you are having issues, have you completely removed the router form the equation and tried connecting a PC directly to the modem?
    Have you tried changing the Ethernet cable that is between the modem and router? Do you have access to a network cable tester? What is the make and model of your router? What version of the firmware is it running? Is it the latest?
  16. biggles
    biggles [H]ard|Gawd
    1,754
    Jul 25, 2005
    Update: it appears the SB6183 modem was overheating. What actually happened is that, about once per week, the internet would drop, and could not be logged into with the ip address. Power cycling did not solve this. But unplugging it and leaving it unplugged for around 10 minutes (long enough for it to cool down) worked. According to this site, there are user reports of this device overheating.
    https://thewirecutter.com/reviews/best-cable-modem/
    Also, unconfirmed reports that this modem is no longer being supported by Comcast.
    Replacing it with the TP-Link TC-7620 (recommendation #2 from above site). This will pair up with a TP-Link AC1750 router. I like pairing networking equipment using the same brand, might help with tech problems and compatibility issues.
  17. SamirD
    SamirD [H]ard|Gawd
    1,714
    Mar 22, 2015
    Thank you for the update. So do you think adding a fan to that particular modem would 'cure' it? Have you called arris about a warranty claim on the unit?
    From what I've read online, comcast won't tell you it's an approved modem, but it works fine if you do a self-install. (y)
    I've seen mixed specs on the tplink--does is only support 16x4 channels? :eek:
  18. biggles
    biggles [H]ard|Gawd
    1,754
    Jul 25, 2005
    Good questions Samir. Already ordered the new modem and did not think to try a fan. Regarding warranty, I suspect Arris would not be helpful since this is an intermittent problem.
  19. SamirD
    SamirD [H]ard|Gawd
    1,714
    Mar 22, 2015
    I'd try the fan and see if it works. If so, then you definitely have enough information to give to Arris for a claim since the problem would be reproducible. (y)
  20. jardows
    jardows [H]ard|Gawd
    1,329
    Jun 10, 2015
    Might take a few phone calls, but if you mention it seems to be overheating, they'll usually authorize a replacement.
  21. GotNoRice
    9,066
    Jul 11, 2001
    Still seems kind of crazy that it is overheating. Like I mentioned in my earlier post in this thread, my 6183 exists in a little building that sits outside and lasted through 105F+ degree days last summer where the interior temperature would probably be similar to the inside of a hot car in a parking lot but the modem never overheated. How hot does it get in your house exactly? Maybe we just have different versions of the 6183.
    Also, even if it's not "supported" anymore, not sure how much that really matters exactly. I still know many in the bay area on Comcast who are still using the 6141 even though that has long since not been supported anymore.
  22. jardows
    jardows [H]ard|Gawd
    1,329
    Jun 10, 2015
    I suspect it's the way it's trying to pull the extra channels, plus the fact that it has a tiny heat sink. When I worked for ARRIS customer support, we'd get a couple calls a day about that model overheating when it was the top-end unit. Replace it, and all problems went away.
  23. SamirD
    SamirD [H]ard|Gawd
    1,714
    Mar 22, 2015
    And there is the chance that it also just has a component that failed that's causing stress on the rest thereby generating more heat than normal.
    In your experience there, do you think a 6183 like this would be exchanged? What if it's outside of warranty?
  24. jardows
    jardows [H]ard|Gawd
    1,329
    Jun 10, 2015
    In warranty, yes. Expect to be asked to ship the unit back to ARRIS at your cost. Out of warranty, no, there won't be a replacement offered. Warranty was two years if purchased new from a retailer, but if purchased second hand, the warranty doesn't transfer.
  25. SamirD
    SamirD [H]ard|Gawd
    1,714
    Mar 22, 2015
    Thank you. What is needed to validate the warranty? Will just the serial number do?
  26. jardows
    jardows [H]ard|Gawd
    1,329
    Jun 10, 2015
    Serial number calculates two years + 3-6 months from the manufacture date. The units move quickly enough, if you purchased from a major vendor it should show up as in warranty, especially if you've had it for a year or less. Otherwise, sending a copy of the purchase receipt will validate the warranty. If needed, should be able to email a scan or screenshot. I'm not sure how quickly they can validate now that they are using a different support center, but we were able to validate emailed copies pretty quickly.
  27. SamirD
    SamirD [H]ard|Gawd
    1,714
    Mar 22, 2015
    Awsome info! Great for anyone that runs across an issue. (y)
    So in the time that you were supporting the modems, which model did you see clearly having more calls or issues?
  28. jardows
    jardows [H]ard|Gawd
    1,329
    Jun 10, 2015
    It would usually depend on what the latest Comcast update did! Overall the products were pretty solid, but each one had its quirks, and the individual cable companies were more than capable of messing things up and blaming the modem! Overall, the return/failure rate was well below 1% of shipped units, so I'd feel comfortable with any of the current products.
  29. SamirD
    SamirD [H]ard|Gawd
    1,714
    Mar 22, 2015
    Haha, that doesn't surprise me. Really great to hear of such a low failure rate--in fact, that's quite impressive when you think of it.
