arp tables and network interfaces
darrenster
strange vm issue:
I'm trying to configure Vyatta in Vmware 6.5 with 5 Ethernet interfaces.
Within Vyatta the interfaces are configured as followed:
eth0 192.168.10.2/24 00:0c:29:59:7b:1d
eth1 192.168.10.3/24 00:0c:29:59:7b:27
eth2 192.168.10.4/24 00:0c:29:59:7b:31
eth3 192.168.10.5/24 00:0c:29:59:7b:3b
eth4 192.168.10.6/24 00:0c:29:59:7b:45
in Vmware, i have the 5 Ethernet interfaces assigned as followed:
network interface 1 -> VMnet1
network interface 2 -> VMnet2
network interface 3 -> VMnet3
network interface 4 -> VMnet4
network interface 5 -> VMnet5
in the VMware network editor, i have VMnet1 bridged to an Ethernet jack on my desktop in which i have my laptop connected to. In the network editor, i have turned off NAT and the DHCP functions.
the laptop ip address is 192.168.10.20
im trying to figure out which network interface in vmware corresponds to which eth interface within vyatta
i have my laptop pinging each of the 5 ip address as listed above thinking the one who responds will be the eth assigned to the vm network interface
however, they all responds to network interface 1. on the laptop when i type "arp -a" the arp table states that each ip address links to 00:0c:29:59:7b:1d
there seems to be some sort of linking issue here and i can not figure it out... does anyone have any ideas of what is going on here????
Thanks!
vmware, meaning vmware workstation, or...?
VMware is a company, not a product ;)
vmware workstation, of course not the company....
Anyways, I think i have figured it out. I dont know how or why it worked this way, but i guess it had something to do with the fact that each interface was on the same subnet. after changing the ip address to separate subnet, it worked as it supposed to.
strange vm issue:
Thanks!
Well since you have all the IP's in the same subnet, there is only 1 routing table. So if you do a 'route print', it will show you the default interface.
