Aria PSU Mod
It would work for you, but you would have to move your radiator to the rear 120mm area where the proprietary PSU vents out... thats all the information I will give until I get my pics and arcticle up on Procooling :p
If I'm not mistaken, you chose the PCI slot side of the case for your install. Doesn't this limit what you can add as far as PCI devices (Sound, TV Tuner, etc...)? Was this due to where the mounting holes were on the PSU? Or, was the CPU cooler too tall for the install to occur on the other side of the case? Also, is it too long to place on the backside of the case?
-E
If I had purchased a 1U HSF for my A64 I could have mounted it on the opposite side. Yes the way I have it mounted currently blocks 2 PCI slots but I only use one for my Audigy. Once I get the article posted you have two choices: block 2 PCI slots, or purchase a 1U HSF. It is really great having a 480 watt PSU in my Aria though :p
