Well, I got this board a couple days ago, and everything seemed fine. Shipped with 1.1 BIOS, and I'm using a "CG" ClawHammer in it. Well, anyway, I installed Windowz xp, and then installed the drivers that came with the board. Now, I'm trying to set up my DSL connection. I connect the modem to the onboard Ethernet port, and attempt to install the software that will let me connect to their network (Bell Sympatico high speed edition, by the way..). To which the installer says that I need to install a NIC. In the more detailed description of the tests it performed, the section under TCP/IP settings was apparently empty. Everything else seemed fine. I'm going to go bitch and complain to my ISP now, but I doubt they would tell me anything beyond "Install a NIC". No room for a NIC though.
