Okay,
Well, I took my computer apart in order to give it a good cleaning/dusting. It's been about a year since I've done this, but since I keep my computer up off the floor, it was relatively clean. Anyway, I disconnected all the cables and once inside, I took out my graphics card and sound card, blew them off with some air, blew off everything else and used a nice little mini-vacuum to suck up all the other stuff.
I never disconnected any cables, save for the CPU Fan, which I took off in order to blow the dust out of the heatsink and reapply some arctic silver ceramique. The CPU was not touched, except by the credit card to spread the thermal compound.
I put everything back together and Viola! No boot.
I looked everything over, made sure everything was connected properly and seated and tried again, and... no boot.
I know it has power, since the green light on the mobo comes on. I know everything is seated correctly, as I've checked it three times now. I know everything is connected, as I've looked and checked all of them and there are no missing/dangling cables.
The only thing that seems not to work is the power on button, even though I never touched it (I did just unplug it and reseat it after looking in the manual to make sure it was in the right spot).
Any ideas? I'm running out of options here, I fear, but I need this computer to work.
Thanks.
Should have mentioned:
Asus A8N-SLI Premium
AMD X2 4400+
Nvidia 7800 GT
2 GB Corsair RAM
Audigy 2 ZS
Nothing is overclocked. I've been having trouble with the speakers cracking/popping so I took it apart because the CPU temps were a little on the high side (about 55C).
drdeutsch
Thanks.
AMD X2 4400+
Nvidia 7800 GT
2 GB Corsair RAM
Audigy 2 ZS
drdeutsch
