ARGB for ASRock and Gigabyte
BUTErvAn
Hi,
I have GPU with RGB, CPU fan with RGB, RAM with RGB, a motherboard with RGB - but the case still looks dark. I guess I need some RGB inside. Any recommendations for addressable RGB strips that I will be able to use with my motherboard?
The ASRock MB:
Supports in total up to 12V/3A, 36W LED Strip 1 x Addressable LED Header
Another MB from Gigabyte:
Supports in total up to 12V/3A, 36W LED Strip 1 x Addressable LED Header?
I can see the ASRock support WS2812B, so magnetic strip with WS2812B and maybe extra plug for extra voltage could the best option? I Would appreciate any help.
What about Gigabyte, do they support WS2812B? nothing is written in the manual.
What about support for WS2813? does it really matter to the MB or it is transparent?
