Areocool fan control unit
xAlex79
Can I hook up multiple fans to one chanel ?
For example I have 3 gentle typhoons 1850rpm on my 3.120 rad can I hook the three of them on a single channel? then I have 2 others on my 2.120 rad, and I have 3 case fans. Can I use a seperate channel for those groups?
Or is it 1 fan 1 channel type deal?
Edit: I just checked the specs and it claims 6w per channels, that sounds very underwhelming. How much power does a typhoon needs?
http://www.frozencpu.com/products/9...roller_Touch_Display_Temp_Sensor_-_Black.html
Edit two: I found this lamptron unit that is 30w per channel
http://www.frozencpu.com/products/1...obus_w_Touch_Screen_-_Black_FCT_HOT_ITEM.html
does seem like it would cope better, anyone with experience in fan controllers?
