I also like the Areca the most, but its also the card there is hardest too get, I need too get it shipped from netherlands if i chose that.
There is also one more thing, that is as far as i can see only the arece supports JBOD and i am thinking alot if i should use JBOD or Rard5 or 6 for my home storrage system. I am going too build a Narco 4224 projekt.
There is just a thing i need too know. If i chose too get the Areca can i run both alot of disk with JBOD and then also a few Raid6 pools and the same time. Or is i limited too one of the raid options. Or can i run multiply raid sets ?
And a little question more, i was thinking of going with the ASUS P8B-E/4L ATX mobo will there be any issues regard one of the raid controllers ? Or is there a better option i will run an xeon cpu, I heard that xeon is better when it comes too storrage ? or should i go with i5 or i7 etc ?
I am not comfortubale with an expender i have thougt about it too, not sure either. But as things are now i am not going too get an expender. I will add an expender when the first narco is full planning and setup 2 narcos with 48 drives total but not befoere the first one is full. It coast alot of money too
