Areca Volume State Failed RAID5
Capt.Frito
I know that this topic has been covered extensively, but my situation is not helped by that information. Maybe this is as simple as deleting the RAID, and re-creating it using the no-init option, but it seems to be a last-resort step, so I am trying to see if such a drastic measure is called for in this case. And I am using cli64 -- I migrated these Areca cards to 2U chassis and lost the RJ45 to access the web interface in the process.
Overview: RAID5, SATA, 12 WD disks, 600GB each (7200GB gross, 6600GB net), Areca 1882x, firmware=v1.51, external Sans Digital JBOD box AS224X6S (internal SAS expander split into two identical 12-disk groups). Situation occurred when I unplugged the JBOD box without offlining it first (my bad).
The disks are 100% good (never failed) and in their original order in the JBOD box (never changed).
One thing I noticed is that there is no listed disk order that I can see. The logs are of no value because this RAID is part of a family of RAIDs that move around from controller to controller and the important information long ago rotated out. I am including it for completeness' sake. Not everything you see will pertain to this specific RAID volume; it's probably safe to ignore any log entry before 4-11-2013.
All help is genuinely appreciated. TIA
Code:
putrid ~ # cli64 vsf info vol=1
Volume Set Information
Volume Set Name : IRAID24
Raid Set Name   : MB1-RAID
Volume Capacity : 6600.0GB
SCSI Ch/Id/Lun  : 00/00/00
Raid Level      : Raid5
Stripe Size     : 64K
Member Disks    : 12
Cache Mode      : Write Back
Tagged Queuing  : Enabled
Volume State    : Failed
GuiErrMsg<0x00>: Success.
putrid ~ # cli64 rsf info
 #  Name             Disks TotalCap  FreeCap MinDiskCap         State
 1  MB1-RAID            12 7200.0GB    0.0GB    600.0GB         Failed
putrid ~ # cli64 disk info
  # Enc# Slot#   ModelName                        Capacity  Usage
  1  01  Slot#1  N.A.                                0.0GB  N.A.
  2  01  Slot#2  N.A.                                0.0GB  N.A.
  3  01  Slot#3  N.A.                                0.0GB  N.A.
  4  01  Slot#4  N.A.                                0.0GB  N.A.
  5  01  Slot#5  N.A.                                0.0GB  N.A.
  6  01  Slot#6  N.A.                                0.0GB  N.A.
  7  01  Slot#7  N.A.                                0.0GB  N.A.
  8  01  Slot#8  N.A.                                0.0GB  N.A.
  9  02  SLOT 01 WDC WD6000BLHX-01V7BV0            600.1GB  MB1-RAID
 10  02  SLOT 02 WDC WD6000BLHX-01V7BV0            600.1GB  MB1-RAID
 11  02  SLOT 03 WDC WD6000BLHX-01V7BV0            600.1GB  MB1-RAID
 12  02  SLOT 04 WDC WD6000BLHX-01V7BV0            600.1GB  MB1-RAID
 13  02  SLOT 05 WDC WD6000BLHX-01V7BV0            600.1GB  MB1-RAID
 14  02  SLOT 06 WDC WD6000BLHX-01V7BV0            600.1GB  MB1-RAID
 15  02  SLOT 07 WDC WD6000BLHX-01V7BV0            600.1GB  MB1-RAID
 16  02  SLOT 08 WDC WD6000BLHX-01V7BV0            600.1GB  MB1-RAID
 17  02  SLOT 09 WDC WD6000BLHX-01V7BV0            600.1GB  MB1-RAID
 18  02  SLOT 10 WDC WD6000BLHX-01V7BV0            600.1GB  MB1-RAID
 19  02  SLOT 11 WDC WD6000BLHX-01V7BV0            600.1GB  MB1-RAID
 20  02  SLOT 12 WDC WD6000BLHX-01V7BV0            600.1GB  MB1-RAID
 21  02  SLOT 13 N.A.                                0.0GB  N.A.
 22  02  SLOT 14 N.A.                                0.0GB  N.A.
 23  02  SLOT 15 N.A.                                0.0GB  N.A.
 24  02  SLOT 16 N.A.                                0.0GB  N.A.
 25  02  SLOT 17 N.A.                                0.0GB  N.A.
 26  02  SLOT 18 N.A.                                0.0GB  N.A.
 27  02  SLOT 19 N.A.                                0.0GB  N.A.
 28  02  SLOT 20 N.A.                                0.0GB  N.A.
 29  02  SLOT 21 N.A.                                0.0GB  N.A.
 30  02  SLOT 22 N.A.                                0.0GB  N.A.
 31  02  SLOT 23 N.A.                                0.0GB  N.A.
 32  02  SLOT 24 N.A.                                0.0GB  N.A.
putrid ~ # cli64 sys info
The System Information
Main Processor     : 800MHz
CPU ICache Size    : 32KB
CPU DCache Size    : 32KB
CPU SCache Size    : 1024KB
System Memory      : 1024MB/1333MHz/ECC
Firmware Version   : V1.51 2013-01-23
BOOT ROM Version   : V1.51 2013-01-23
Serial Number      : Y143CADDAR200113
Controller Name    : Sans Dig
Current IP Address : 172.16.3.169
putrid ~ # cli64 event info
Date-Time            Device           Event Type            Elapsed Time Errors
2013-05-04 14:06:47  172.016.003.219  HTTP Log In
2013-05-04 13:38:43  H/W MONITOR      Raid Powered On
2013-05-04 13:28:57  SW API Interface API Log In
2013-05-04 13:13:32  SW API Interface API Log In
2013-04-30 14:14:02  SW API Interface API Log In
2013-04-29 11:30:10  H/W MONITOR      Raid Powered On
2013-04-29 11:22:13  H/W MONITOR      Raid Powered On
2013-04-27 08:06:31  172.016.003.219  HTTP Log In
2013-04-12 20:53:07  172.016.003.219  HTTP Log In
2013-04-11 15:56:15  H/W MONITOR      Raid Powered On
2013-04-11 15:53:22  H/W MONITOR      Raid Powered On
2013-04-11 15:43:24  H/W MONITOR      Raid Powered On
2013-03-25 21:08:46  Enclosure#2      Removed
2013-03-25 21:08:46  Enc#2 SES2Device Device Removed
2013-03-25 21:08:46  Enc#2 Disk-08    Device Removed
2013-03-25 21:08:46  Enc#2 Disk-07    Device Removed
2013-03-25 21:08:45  Enc#2 Disk-06    Device Removed
2013-03-25 21:08:45  Enc#2 Disk-05    Device Removed
2013-03-25 21:08:44  Enc#2 Disk-04    Device Removed
2013-03-25 21:08:44  Enc#2 Disk-03    Device Removed
2013-03-25 21:08:44  Enc#2 Disk-02    Device Removed
2013-03-25 21:08:44  Enc#2 Disk-01    Device Removed
2013-03-25 21:08:17  MB1-RAID         Offlined
2013-03-25 21:07:03  IRAID            Complete Check        000:50:18    0
2013-03-25 20:25:47  172.016.003.219  HTTP Log In
2013-03-25 20:16:45  IRAID            Start Checking
2013-03-25 20:14:10  H/W MONITOR      Raid Powered On
2013-03-25 20:11:52  H/W MONITOR      Raid Powered On
2013-03-22 23:01:42  172.016.003.219  HTTP Log In
2013-03-22 22:50:32  H/W MONITOR      Raid Powered On
2013-03-22 21:10:58  H/W MONITOR      Raid Powered On
2013-03-22 21:00:57  H/W MONITOR      Raid Powered On
2013-03-22 20:58:01  H/W MONITOR      Raid Powered On
2013-03-22 19:46:17  172.016.003.219  HTTP Log In
2013-03-21 08:24:16  172.016.003.219  HTTP Log In
2013-03-20 20:08:57  H/W MONITOR      Raid Powered On
2013-03-20 20:04:56  H/W MONITOR      Raid Powered On
2013-03-20 12:14:38  H/W MONITOR      Raid Powered On
2013-03-20 12:13:45  RS232 Terminal   VT100 Log In
2013-03-20 12:13:08  H/W MONITOR      Raid Powered On
2013-03-20 12:10:48  H/W MONITOR      Raid Powered On
2013-03-20 12:08:16  Enclosure#2      Removed
2013-03-20 12:08:16  Enc#2 SES2Device Device Removed
2013-03-20 12:08:16  Enc#2 SLOT 12    Device Removed
2013-03-20 12:08:15  Enc#2 SLOT 11    Device Removed
2013-03-20 12:08:15  Enc#2 SLOT 10    Device Removed
2013-03-20 12:08:15  Enc#2 SLOT 09    Device Removed
2013-03-20 12:08:14  Enc#2 SLOT 08    Device Removed
2013-03-20 12:08:14  Enc#2 SLOT 07    Device Removed
2013-03-20 12:08:13  Enc#2 SLOT 06    Device Removed
2013-03-20 12:08:13  Enc#2 SLOT 05    Device Removed
2013-03-20 12:08:13  Enc#2 SLOT 04    Device Removed
2013-03-20 12:08:12  Enc#2 SLOT 03    Device Removed
2013-03-20 12:08:12  Enc#2 SLOT 02    Device Removed
2013-03-20 12:08:12  Enc#2 SLOT 01    Device Removed
2013-03-20 12:05:15  172.016.003.239  HTTP Log In
2013-03-20 11:56:16  MB1-RAID         Offlined
2013-03-20 11:52:39  RS232 Terminal   VT100 Log In
2013-03-20 11:34:50  RS232 Terminal   VT100 Log In
2013-03-20 10:41:08  H/W MONITOR      Raid Powered On
2013-03-20 10:37:10  RS232 Terminal   VT100 Log In
2013-03-20 10:30:49  MB1-RAID         Offlined
2013-03-20 10:19:07  RS232 Terminal   VT100 Log In
2013-03-20 10:15:33  H/W MONITOR      Raid Powered On
2013-03-20 10:11:29  H/W MONITOR      Raid Powered On
2013-03-20 09:31:21  Enclosure#2      Removed
2013-03-20 09:31:21  Enc#2 SES2Device Device Removed
2013-03-20 09:31:20  Enc#2 Disk-09    Device Removed
2013-03-20 09:31:20  Enc#2 Disk-10    Device Removed
2013-03-20 09:31:20  Enc#2 Disk-11    Device Removed
2013-03-20 09:31:19  Enc#2 Disk-12    Device Removed
2013-03-20 09:31:19  Enc#2 Disk-13    Device Removed
2013-03-20 09:31:18  Enc#2 Disk-14    Device Removed
2013-03-20 09:31:18  Enc#2 Disk-15    Device Removed
2013-03-20 09:31:18  Enc#2 Disk-16    Device Removed
2013-03-20 09:30:27  Raid Set # 000   Offlined
2013-03-20 03:23:31  Sans Dig-VOL#000 Complete Check        005:48:51    3669116
2013-03-19 21:34:40  Sans Dig-VOL#000 Start Checking
2013-03-19 21:34:05  Enc#2 Disk-10    Device Inserted
2013-03-19 21:34:05  Enc#2 Disk-11    Device Inserted
2013-03-19 21:34:05  Enc#2 Disk-12    Device Inserted
2013-03-19 21:34:05  Enc#2 Disk-13    Device Inserted
2013-03-19 21:34:05  Enc#2 Disk-15    Device Inserted
2013-03-19 21:34:05  Enc#2 Disk-14    Device Inserted
2013-03-19 21:34:05  Enc#2 Disk-09    Device Inserted
2013-03-19 21:34:05  Enc#2 Disk-16    Device Inserted
2013-03-19 21:34:05  Enclosure#2      Added
2013-03-19 21:31:48  172.016.003.219  HTTP Log In
2013-03-19 21:28:24  H/W MONITOR      Raid Powered On
2013-03-19 21:22:31  Enc#2 SES2Device Time Out Error
2013-03-19 21:05:41  Sans Dig-VOL#000 Start Checking
2013-03-19 21:01:01  172.016.003.219  HTTP Log In
2013-03-19 20:56:26  Enc#2 Disk-13    Device Inserted
2013-03-19 20:56:26  Enc#2 Disk-10    Device Inserted
2013-03-19 20:56:26  Enc#2 Disk-12    Device Inserted
2013-03-19 20:56:26  Enc#2 Disk-09    Device Inserted
2013-03-19 20:56:26  Enc#2 Disk-11    Device Inserted
2013-03-19 20:56:26  Enc#2 Disk-14    Device Inserted
2013-03-19 20:56:26  Enc#2 Disk-15    Device Inserted
2013-03-19 20:56:26  Enc#2 Disk-16    Device Inserted
2013-03-19 20:56:26  Enclosure#2      Added
2013-03-19 20:42:01  H/W MONITOR      Raid Powered On
 2013-03-19 20:40:40  H/W MONITOR      Raid Powered On
2013-03-19 20:36:33  H/W MONITOR      Raid Powered On
2013-03-19 20:27:14  H/W MONITOR      Raid Powered On
2013-03-19 20:22:05  H/W MONITOR      Raid Powered On
2013-03-19 20:20:44  H/W MONITOR      Raid Powered On
2013-03-19 20:19:50  H/W MONITOR      Raid Powered On
2013-03-19 20:07:31  Enclosure#2      Removed
2013-03-19 20:07:31  Enc#2 SES2Device Device Removed
2013-03-19 20:07:30  Enc#2 Disk-08    Device Removed
2013-03-19 20:07:30  Enc#2 Disk-07    Device Removed
2013-03-19 20:07:30  Enc#2 Disk-06    Device Removed
2013-03-19 20:07:29  Enc#2 Disk-05    Device Removed
2013-03-19 20:07:29  Enc#2 Disk-04    Device Removed
2013-03-19 20:07:28  Enc#2 Disk-03    Device Removed
2013-03-19 20:07:28  Enc#2 Disk-02    Device Removed
2013-03-19 20:07:28  Enc#2 Disk-01    Device Removed
2013-03-19 20:07:12  MB1-RAID         Offlined
2013-03-19 20:03:49  Enc#2 Disk-04    Device Inserted
2013-03-19 20:03:49  Enc#2 Disk-05    Device Inserted
2013-03-19 20:03:49  Enc#2 Disk-03    Device Inserted
2013-03-19 20:03:39  Enc#2 Disk-01    Device Inserted
2013-03-19 20:03:39  Enc#2 Disk-02    Device Inserted
2013-03-19 20:03:21  Enclosure#2      Added
2013-03-19 20:03:19  Enclosure#2      Removed
2013-03-19 20:03:19  Enc#2 SES2Device Device Removed
2013-03-19 20:03:18  Enc#2 Disk-08    Device Removed
2013-03-19 20:03:18  Enc#2 Disk-07    Device Removed
2013-03-19 20:03:18  Enc#2 Disk-06    Device Removed
2013-03-19 20:03:17  Enc#2 Disk-05    Device Removed
2013-03-19 20:03:17  Enc#2 Disk-04    Device Removed
2013-03-19 20:03:16  Enc#2 Disk-03    Device Removed
2013-03-19 20:03:16  Enc#2 Disk-02    Device Removed
2013-03-19 20:03:16  Enc#2 Disk-01    Device Removed
2013-03-19 20:02:10  MB1-RAID         Offlined
2013-03-19 11:04:30  IRAID            Complete Check        000:50:07    0
2013-03-19 10:14:23  IRAID            Start Checking
2013-03-18 10:13:27  IRAID            Complete Check        000:50:04    0
2013-03-18 09:23:22  IRAID            Start Checking
2013-03-18 09:22:55  Enc#2 Disk-07    Device Inserted
2013-03-18 09:22:55  Enc#2 Disk-08    Device Inserted
2013-03-18 09:22:55  Enc#2 Disk-03    Device Inserted
2013-03-18 09:22:55  Enc#2 Disk-02    Device Inserted
2013-03-18 09:22:55  Enc#2 Disk-06    Device Inserted
2013-03-18 09:22:55  Enc#2 Disk-05    Device Inserted
2013-03-18 09:22:55  Enc#2 Disk-04    Device Inserted
2013-03-18 09:22:55  Enc#2 Disk-01    Device Inserted
2013-03-18 09:22:55  Enclosure#2      Added
2013-03-18 09:22:53  Enc#2 Disk-08    Device Removed
2013-03-18 09:22:52  Enc#2 Disk-07    Device Removed
2013-03-18 09:22:52  Enc#2 Disk-06    Device Removed
2013-03-18 09:22:52  Enc#2 Disk-05    Device Removed
2013-03-18 09:22:51  Enc#2 Disk-04    Device Removed
2013-03-18 09:22:51  Enc#2 Disk-03    Device Removed
2013-03-18 09:22:50  Enc#2 Disk-02    Device Removed
2013-03-18 09:22:50  Enc#2 Disk-01    Device Removed
2013-03-18 09:22:50  Enclosure#2      Removed
2013-03-18 09:22:50  Enc#2 SES2Device Device Removed
2013-03-18 09:21:16  Enc#2 Disk-01    Device Inserted
2013-03-18 09:20:58  Enc#2 Disk-06    Device Inserted
2013-03-18 09:20:50  Enc#2 Disk-04    Device Inserted
2013-03-18 09:20:50  Enc#2 Disk-05    Device Inserted
2013-03-18 09:20:48  Enclosure#2      Added
2013-03-18 09:20:46  Enclosure#2      Removed
2013-03-18 09:20:46  Enc#2 SES2Device Device Removed
2013-03-18 09:20:45  Enc#2 Disk-08    Device Removed
2013-03-18 09:20:45  Enc#2 Disk-07    Device Removed
2013-03-18 09:20:45  Enc#2 Disk-06    Device Removed
2013-03-18 09:20:44  Enc#2 Disk-05    Device Removed
2013-03-18 09:20:44  Enc#2 Disk-04    Device Removed
2013-03-18 09:20:43  Enc#2 Disk-03    Device Removed
2013-03-18 09:20:43  Enc#2 Disk-02    Device Removed
2013-03-18 09:20:43  Enc#2 Disk-01    Device Removed
2013-03-18 09:19:36  MB1-RAID         Offlined
2013-03-17 22:14:58  IRAID            Complete Check        003:00:43    0
2013-03-17 19:17:08  172.016.003.219  HTTP Log In
2013-03-17 19:14:14  IRAID            Start Checking
2013-03-17 19:11:36  Enc#2 Disk-08    Device Inserted
2013-03-17 19:11:36  Enc#2 Disk-07    Device Inserted
2013-03-17 19:11:36  Enc#2 Disk-06    Device Inserted
2013-03-17 19:11:36  Enc#2 Disk-05    Device Inserted
2013-03-17 19:11:36  Enc#2 Disk-04    Device Inserted
2013-03-17 19:11:36  Enc#2 Disk-03    Device Inserted
2013-03-17 19:11:36  Enc#2 Disk-01    Device Inserted
2013-03-17 19:11:36  Enc#2 Disk-02    Device Inserted
2013-03-17 19:11:36  Enclosure#2      Added
2013-03-17 19:08:34  H/W MONITOR      Raid Powered On
2013-03-17 19:07:38  Enclosure#2      Removed
2013-03-17 19:07:38  Enc#2 SES2Device Device Removed
2013-03-17 19:07:38  Enc#2 SLOT 14    Device Removed
2013-03-17 19:07:38  Enc#2 SLOT 19    Device Removed
2013-03-17 19:07:38  Enc#2 SLOT 18    Device Removed
2013-03-17 19:07:38  Enc#2 SLOT 17    Device Removed
2013-03-17 19:07:38  Enc#2 SLOT 24    Device Removed
2013-03-17 19:07:38  Enc#2 SLOT 23    Device Removed
2013-03-17 19:07:38  Enc#2 SLOT 22    Device Removed
2013-03-17 19:07:38  Enc#2 SLOT 21    Device Removed
2013-03-17 19:07:38  Enc#2 SLOT 16    Device Removed
2013-03-17 19:07:38  Enc#2 SLOT 15    Device Removed
2013-03-17 19:07:38  Enc#2 SLOT 13    Device Removed
2013-03-17 19:07:37  MB1-RAID         RaidSet Degraded
2013-03-17 19:07:37  IRAID24          Volume Degraded
2013-03-17 19:07:37  Enc#2 SLOT 20    Device Removed
2013-03-17 19:07:37  IRAID24          Volume Failed
2013-03-17 19:07:36  IRAID24          Volume Failed
2013-03-17 19:07:35  IRAID24          Volume Failed
2013-03-17 19:07:34  IRAID24          Volume Failed
2013-03-17 19:07:34  MB1-RAID         RaidSet Degraded
2013-03-17 19:04:51  H/W MONITOR      Raid Powered On
2013-03-17 19:03:55  RS232 Terminal   VT100 Log In
2013-03-17 18:50:10  172.016.003.239  HTTP Log In
2013-03-17 18:49:08  RS232 Terminal   VT100 Log In
2013-03-17 18:48:51  H/W MONITOR      Raid Powered On
2013-03-17 18:46:13  MB1-RAID         Rebuild RaidSet
2013-03-17 18:46:12  Enc#2 SLOT 21    Device Inserted
2013-03-17 18:46:06  Enc#2 SLOT 21    Device Removed
2013-03-17 18:40:51  172.016.003.239  HTTP Log In
2013-03-17 18:32:36  RS232 Terminal   VT100 Log In
2013-03-17 18:32:06  H/W MONITOR      Raid Powered On
2013-03-17 18:30:33  RS232 Terminal   VT100 Log In
2013-03-17 18:28:27  H/W MONITOR      Raid Powered On
2013-03-17 18:25:08  Enc#2 SLOT 18    Device Inserted
2013-03-17 18:25:08  Enc#2 SLOT 24    Device Inserted
2013-03-17 18:25:08  Enc#2 SLOT 23    Device Inserted
2013-03-17 18:25:08  Enc#2 SLOT 22    Device Inserted
2013-03-17 18:25:08  Enc#2 SLOT 17    Device Inserted
2013-03-17 18:25:08  Enc#2 SLOT 20    Device Inserted
2013-03-17 18:25:08  Enc#2 SLOT 19    Device Inserted
2013-03-17 18:25:08  Enc#2 SLOT 14    Device Inserted
2013-03-17 18:25:08  Enc#2 SLOT 13    Device Inserted
2013-03-17 18:25:08  Enc#2 SLOT 21    Device Inserted
2013-03-17 18:25:08  Enc#2 SLOT 15    Device Inserted
2013-03-17 18:25:08  Enc#2 SLOT 16    Device Inserted
2013-03-17 18:25:07  Enclosure#2      Added
2013-03-17 18:15:25  Enclosure#2      Removed
2013-03-17 18:15:25  Enc#2 SES2Device Device Removed
2013-03-17 18:15:25  Enc#2 SLOT 11    Device Removed
2013-03-17 18:15:25  Enc#2 SLOT 10    Device Removed
2013-03-17 18:15:25  Enc#2 SLOT 09    Device Removed
2013-03-17 18:15:25  Enc#2 SLOT 08    Device Removed
