I'm playing around with my new Areca 1260 and I've already hit a data corruption issue. I have an 9 drive raid group (500GB each) that I've carved into a 2TB R5 lun. I presented the LUN to my ESX guest using Raw Device Mapping and all seemed to go pretty well. It's as fast a i need (200MB/s read, 400MB/s write) and that's good enough for me.
So I loaded it up the other day with media files and started to do some editing...again, everything seemed fine. I had to move and reboot the server a couple of times...but everything came up clean, no errors in the RAID terminal.
Today, however, I noticed that half of my data went missing and I got tons of IO errors accessing directories. I ran an fsck and it basically took half of my data out and dumped it into lost+found. that's a bit un-nerving. I have since cleaned it up again and replaced the data, but it got me thinking....
I've set the controller for agressive caching. I basically turned on all of the caching possible, since it's on a UPS and I'm not really worried about a power outage. But now I'm thinking I might back off this.
So what should i leave on and what should I turn off?
(spin-down is also turned on for the disks. That's one thing I definitely want to keep).
thanks
thanks
