wkearney99
- Sep 8, 2010
Should it be possible to swap out an Areca 1260 for a 1230 and have everything still work ok?
I've got a windows 7 x64 box that has a 1260 in it and I want to replace that with a 1230. I want to use the 16 port card in another machine. I swapped the cards and the the OS appears to boot but then spontaneously reboots. Booting in safe mode shows 'disk.sys' to be the last thing loading before the reboot. This is not a blue screen, just a hard reset. Both cards have the same 1.49 firmware. Both have the battery backup, the same one that's always been connected to each. I moved the cards and batteries as a pair. I have not put the 1260 into the other box yet.
The firmware in the 1230, and the web interface both show that the RAID and volume sets are present and working properly. When the OS boots it shows the correct boot menu. So it's not like the volumes aren't getting connected.
I'm puzzled here, is there something different about the 1230 from the 1260 that would matter? They were both installed using the same x64 version of the storport driver. I don't have a spare x4 slot in this particular machine so I can't have both cards installed at the same time.
