hi,
I am thinking of buying one of the areca external e-sata raid boxes from this website.
http://www.tekramonline.com/External_RAID_Boxes.html
My choice will be between the ARC-4020C and ARC-5020. On the ARC-5020 description, it says it has built-in RAID controller. Does that mean I don't need to buy a separate PCI-e RAID card? Also, why is it cheaper than ARC-4020C?
My pc doesn't have a e-Sata port, which one do you recommend?
Thanks!
Thanks!
