grandswede
- May 4, 2008
My ARECA 1220 raid controller had 4 drives in a raid 5. It reported a problem occuring, where the only working drive was the one on channel 3, all others were down.
I stopped the machine and fixed the power to the other drives. But now, I have two raidsets instead of one. The drive on channel 3 is one raidset, and it is failed, for obvious reasons, but still ocnnected to the volume set.
The other three drives is reported as a raidset as well, with the same name, and not connected to a volume set. They are currnently both inactive and incomplete.Even if I disconnect channel 3 and restart, the three drives remain incomplete and without connection to a raid set.
How do I save the data and get the raid back up online?
1. I could try activating the three drives, hope for them becoming degraded, then create a volume set on them, but I fear then my data wil be lost.
2. I could disconnect the three drives, and add one at a time to the failed single disk still having the volume set associated with it. Maybe it will accept the disks and end up as degraded.
3. There are commands like migrate and rescue, maybe one of them can be used? But then how?
--- Help needed ---
--- Help needed ---
