Areca 1883IX-16
seavideo
My raid just degraded
After I use rescue , signat
the raid just come back .. but the volume not back
how to restore the raid into volume
* I just scare if I create a volume ( my data will lost )
any solution
Why did you run those commands? They're generally reserved for when your RAID set is hosed, not when it's degraded. Did your RAID set disappear completely? If not, you just overwrote the original metadata (hopefully with the correct details) and should have just replaced the failed drive (marking it as a hot-spare).
Your best bet is to create a volume set without initialization, though some logs would help to see everything you've done.
Actually I am rebuilding the raid .. suddenly there whole volume disappear
I did run the command
on the web interface ..and also bios
can i still recovery the volume
or I need to redo the volume
Please post the complete log from the card. Do you have the geometries of your array (Stripe Size, block size) pre-changes? Do you have a backup?
