Areca 1883-16
seavideo
areca 1883- 16 bay using deskstar hdd 10tb nas hdd and chenbro rm31616
After building The nas into RAID 6
It Seem ok But After we try to copy File in
The nas suddenly degraded
Is it deskstar hdd not compatible
It happen to both of My areca 1883
Is it a Must to use enterprise hgst
Or my chasis not Good enough Or power issue
http://www.chenbro.com/en-global/products/RackmountChassis/3U_Chassis/RM31616
Please post a complete log from your card(s). Are the firmware and BIOS upgraded on all the Arecas? What motherboard are you using? What power supplie(s) are you using? Unfortunately, per the latest Areca HCL of last month, your drives are not certified for your card, which may or may not be an issue. What is the host OS? Bare metal or virtualized? How are you initiating the data copying? Please respond with the requested information so we can get a better idea what is actually happening.
mb is super micro
I am using 2 areca 1883 x16
using HGST 10tb HDD
But 16 bay chenbroRM31616
The both NAS areca raid keep on degarded
some tell me nas hgst cannot be use
some said need to send the areca for warranty
some said need enterprise HDD
NAS HDD is not suitable
more the 4 to 6 hdd must use enterprise
or else there will be a vibration Issue
for 16 bay casing
I turst areca so much.. I am not sure how to solve my problem
keep on problem
You still have not posted the information requested almost a year ago. Please post the entire log which you can get from either the ARCHTTP or through a browser connected to the ethernet port. What is the host OS? Bare metal or virtualized? How are you initiating the data copying? Please respond with the requested information so we can get a better idea what is actually happening. Have you tried changing the cables connection the Areca to the enclosure?
