So during a migration from 13 to 14 drives in a raid 6 array, I inserted 2 new drives into the computer (to be used later). About some time later I noticed my file server rebooting about every 5 minutes. I plugged up a monitor to see what was going on and noticed the raid firmware timing out and restarting it. A suggestion I found was to reset the onboard cache...probably the stupidest thing I could have done. But unfortunately I had taken the advice and did it without thinking about migration cache.
Areca web console showed that one of the new drives had failed, and that drive 7 of the array had failed and that drive 8 had gone missing. Removing the doa drive allowed the firmware to boot but the raid is now in the failed migration state.
This is a personal system; most of the data on here is backed up elsewhere, however there are certain things on here that I would like to recover.
I was curious as how to to about this as I'm now trying to research all my options before I try anything destructive (more so x.x).
What's the RESCUE command do? would i have to delete the set first and hope it finds it? since it was migrating (it was at 30%, just fyi) would it even see all the data? What about the LeVeL2ReScUe i read about in another post (shame it didn't say what it did)
I might even be okay if i have to use recovery software (r-studio comes to mind) even if i had to let it scan 14 drives to pull the first 30%, and then again on 13 drives for the remainder, minus the probably destroyed data that it was currently processing. I don't even know if that's possible, as I'm not experienced in recovering raids.
snippet of event log
Code:
2013-04-21 22:29:23 010.001.000.050 HTTP Log In
2013-04-21 22:26:49 Incomplete RAID Discovered
2013-04-21 22:26:49 H/W Monitor Raid Powered On
2013-04-21 22:25:06 RS232 Terminal VT100 Log In
2013-04-21 22:24:23 H/W Monitor Raid Powered On
2013-04-21 22:24:22 Enc#2 SLOT 17 Device Removed
2013-04-21 22:24:20 Enc#2 SLOT 18 Device Removed
2013-04-21 22:21:57 010.001.000.050 HTTP Log In
2013-04-20 19:03:02 010.001.000.050 HTTP Log In
2013-04-20 18:43:02 010.001.000.050 HTTP Log In
2013-04-20 18:37:16 000:0004C1001000 Lost Rebuilding/Migration LBA
2013-04-20 18:37:16 Incomplete RAID Discovered
2013-04-20 18:37:15 H/W Monitor Raid Powered On
2013-04-20 18:36:24 ARC-1680-VOL#000 Start Migrating
2013-04-20 18:36:22 Raid #1 Rebuild RaidSet
2013-04-20 18:36:22 ARC-1680-VOL#000 Failed Volume Revived
2013-04-20 18:36:22 Enc#2 SLOT 12 Device Inserted
2013-04-20 18:36:18 Enc#2 SLOT 07 Device Removed
2013-04-20 18:36:18 Raid #1 RaidSet Degraded
2013-04-20 18:36:17 Enc#2 SLOT 12 Device Removed
2013-04-20 18:36:17 Raid #1 RaidSet Degraded
2013-04-20 18:36:16 ARC-1680-VOL#000 Volume Failed
2013-04-20 18:36:15 ARC-1680-VOL#000 Stop Migration 000:00:05
2013-04-20 18:36:15 ARC-1680-VOL#000 Volume Failed
2013-04-20 18:36:10 ARC-1680-VOL#000 Start Migrating
2013-04-20 18:36:09 Raid #1 Rebuild RaidSet
2013-04-20 18:36:09 Enc#2 SLOT 07 Device Inserted
2013-04-20 18:36:08 Raid #1 Rebuild RaidSet
2013-04-20 18:36:08 ARC-1680-VOL#000 Failed Volume Revived
2013-04-20 18:36:08 Enc#2 SLOT 08 Device Inserted
2013-04-20 18:36:07 Raid #1 Rebuild RaidSet
2013-04-20 18:36:07 Enc#2 SLOT 12 Device Inserted
2013-04-20 18:36:04 Enc#2 SLOT 08 Device Removed
2013-04-20 18:36:04 Enc#2 SLOT 07 Device Removed
2013-04-20 18:36:03 Raid #1 RaidSet Degraded
2013-04-20 18:36:03 Enc#2 SLOT 12 Device Removed
2013-04-20 18:36:01 ARC-1680-VOL#000 Volume Failed
2013-04-20 18:36:00 Raid #1 Rebuild RaidSet
2013-04-20 18:36:00 Enc#2 SLOT 08 Device Inserted
2013-04-20 18:35:59 Raid #1 Rebuild RaidSet
2013-04-20 18:35:59 ARC-1680-VOL#000 Failed Volume Revived
2013-04-20 18:35:59 Enc#2 SLOT 07 Device Inserted
2013-04-20 18:35:56 Enc#2 SLOT 08 Device Removed
2013-04-20 18:35:55 Raid #1 RaidSet Degraded
2013-04-20 18:35:55 Enc#2 SLOT 07 Device Removed
2013-04-20 18:35:54 Raid #1 RaidSet Degraded
2013-04-20 18:35:53 ARC-1680-VOL#000 Volume Failed
2013-04-20 18:35:52 ARC-1680-VOL#000 Stop Migration 000:00:04
