Areca 1680 Incomplete Array
Hardy
I have an Areca 1680ix-24 controlling 48 SATA disks (3 RAID arrays), some via an Areca SAS Expander card. I also have the Areca battery-backup unit.
Windows froze and I had to hard-power the machine. When it came back online, one of the RAID arrays was incomplete. The Areca event log showed 2 drives were missing from that array (slots # 6 and # 13).
One of the "missing" drives (slot # 6) was identified as having been "removed", while the other (slot # 13) said it was connected but not part of the array (i.e., it was a "free" drive).
Further, the log has two entries for "Lost Rebuilding/Migration LBA".
I disconnected the "removed" drive (slot # 6), then reconnected, and it now is listed as part of the array.
However, I can't seem to get the other drive (slot # 13) to be added back to the array -- I tried to remove and reinsert it, but it still shows as "free".
This array is RAID 6.
I appreciate any advice on how to proceed.
======= E V E N T . L O G =======
2012-06-23 11:24:22 Enc#3 SLOT 13 Device Inserted
2012-06-23 11:23:51 Enc#3 SLOT 13 Device Removed
2012-06-23 11:22:53 Enc#3 SLOT 06 Device Inserted
2012-06-23 11:05:14 Proxy Or Inband HTTP Log In
2012-06-23 10:45:13 E3 PowerSupply02 Removed
2012-06-23 10:45:13 E3 PowerSupply01 Removed
2012-06-23 10:45:13 E3 Fan 04 Removed
2012-06-23 10:45:13 E3 Fan 03 Removed
2012-06-23 10:45:13 E3 Fan 02 Removed
2012-06-23 10:45:13 E3 Fan 01 Removed
2012-06-23 10:44:43 002:00000106E200 Lost Rebuilding/Migration LBA
2012-06-23 10:44:43 002:00000106CC00 Lost Rebuilding/Migration LBA
2012-06-23 10:44:43 Incomplete RAID Discovered
2012-06-23 10:44:42 H/W Monitor Raid Powered On
2012-06-23 10:44:10 Enc#7 Time Out Error
2012-06-23 11:01:16 Raid Set # 002 Rebuild RaidSet
2012-06-23 11:01:14 Enc#3 SLOT 06 Device Inserted
2012-06-23 11:01:13 Enc#3 SLOT 06 Time Out Error
2012-06-23 11:00:38 Enc#3 SLOT 06 Time Out Error
2012-06-23 11:00:12 JPB EXTRA DRIVE Start Rebuilding
2012-06-23 11:00:11 Enc#3 SLOT 13 Device Removed
2012-06-23 11:00:10 Raid Set # 002 RaidSet Degraded
2012-06-23 11:00:07 Raid Set # 002 Rebuild RaidSet
2012-06-23 11:00:07 Enc#3 SLOT 13 Device Inserted
2012-06-23 11:00:06 JPB EXTRA DRIVE Volume Degraded
2012-06-23 10:56:25 Enc#3 SLOT 06 Device Removed
2012-06-23 10:56:14 Enc#3 SLOT 06 Device Failed
2012-06-23 10:56:13 Raid Set # 002 RaidSet Degraded
2012-06-23 10:56:11 JPB EXTRA DRIVE Volume Degraded
2012-06-23 10:55:28 Enc#3 SLOT 06 Time Out Error
======= E N D . E V E N T . L O G . ( T R U N C A T E D ) =======
