areca 1220 or 1222
rtrimarchi
Hi guys.... ;)
considering my target:
- OS bootable - raid 1 (#2 WD SATAII Enterprise HD)
- DATA - raid 6 (#5 WD1002fbys SATA II enterprise hd)
where OS+DATA availability is the most important think.....
I cannot chose between the areca 1220 and 1222.
They got the same exact price on newegg....
Can you help me to take a decision... also based on your personal experiences :D
I'd be really THANKFULL :p
I'd pick 1222. Faster ram and minisas connectors make things a little cleaner.
Or LSI 9260-8i which is basically the same price and has a newer controller, SAS 2/ SATA support and twice the onboard cache (no out of band management though).
I was thinkin to get the 1222 too .... but I only have great experiences with 1220...even if it is older.
Is any of you using it (1222) with the hardware scenario that I will be facing to :confused:
