Are truly silent PC's actually possible?
SatinSpiral
Okay, I recognise that you can water cool pretty much everything inside your box, but what do you do about the noise from the PSU fan?
there was one case that had all heatpipes in it and no fans at all. Only noise would be from the hard drive.
I can't remember who made it but it was really neat looking.
Well, there are fanless PSUs, but there's still noise from the water pump and rad fans. The closest you can get to a silent PC would be one of Zalman TNN heatpipe cooling systems. They use heatpipes to cool the GPU, CPU, and NB and have no fans. Then put in a fanless PSU and a heatpipe HDD cooler. That would eliminate all fan noise, but there would still be the sound of the HDD spinning though, so it wouldn't be "truely silent", but that's as close as you'd get. Unless of course you bought a solid-state HDD, which currently goes for about $1000/GB.
thanks
I'd recommend the Seasonic S12 series of PSU's if you want silence/quiet. They seem to be rewarded a lot for their silence but also for their high efficiency.
once we have nothing in the box that rotates, then it will be possible.
A well-planned air-cooling setup can be close to silence, and it saves you a lot of money. Doesn't have to be all water-cooled.
Roger that
an expensive as hell but truly quiet system, NO NOISE AT ALL. It uses heatpipes for al of the cpu and gpu cores as well as other things, then has sound dampening materials around the psu (which is a custom zalman quiet model anyway) as well as the HDD bays so when all is set up there is not a single noise. The heat is taken from the heatpipes and is distributed out through the case itself, since the sides of the case are infact big heatsinks connected to the heatpipes.
http://www.zalmanusa.com/usa/product/view.asp?idx=151&code=020
