- Jun 1, 2004
Currently priming right now, so for stable...is this ok?
jubei said:Did you swap out your chaintech vnf3-250? Yeah, those temps are fine. The voltage is also fine, but I always get a bit sketchy bumping mine past 1.65v. I'm a pussy though. I think the critical temps for the AMD64 are around 90c.
dabiggoober said:This might be a stupid question and if it is excuse my igorance. But how did you get your HTT to show over 300 while your mem is clocked to 217????
WookieRookie said:What are normal CPU and Memory voltages for AMD64 rigs?
v_lestat said:ohh i like that
man good overclock.
im currently running my 3200+ Clawhammer at 3.5ghz fsb = 350 HTT@3 cas at 3-3-3-8-7-16 wish there was a way to adjust the 16 but ,,,nope. the asus K8N-E Deluxe only has VDIMM up tp 2.7v but the ocz pc4000 allows me to have a lot of fsb room to play with.
VCore is 1.6.v.
i must say i am very happy with this setup. this smokes my old system. the one you see in my sig.
don_vercetti said:If those temps are under load, that's pretty good. That 12v rail does look a little low, but if that's under load it should be all right.
Basically, aim to keep your temperatures below 60C.
And that's a pretty good overclock there as well. What motherboad are you using now?
