Are these temps too high?
Kevin5255
Hey everyone, I just installed a new motherboard on my computer and I'm afraid that it's runniong a bit hot right now. I'd like it if you guys would let me know if these temps are tolerable or not. I don't need the components too cool, but I don't want anything to get damaged. On high load (crysis and benchmarks) my temps look like this:
8800GT: 80C- I turned the fan up in ntune and it stayed under 65C. will that be ok?
Core1: 32C
Core2: 40C
I know I've got a big gap in temps here- is this difference too much? I've thought about replacing my HSF for my processor, but my case doesnt have very good airflow anyway. Should I look into lowering my temps?
The core temps on your processor are normal. They're fine.
For the video card, 65C is tolerable, whereas 80C isn't. You'll need to keep using nTune to run the GPU fan at 100%... or you could replace the stock cooler with an aftermarket heatsink and fan.
