Are these Temps okay?
i dunno when 38c wouldn't be ok... honestly. system is fine too.
nice work. also, may want to learn to use the edit as i see you have another thread with the same title open.
Is that full load or idle? If its full load its completely fine, and if its at idle, its still not too bad.
If it's idle they are okay, if it's full load, they are damn impressive.
I hardly ever see system temp > cpu temp. Do you have good case cooling?
the case and pwm are a little warm for my taste my temps are closer together your system temp is pretty warm if you get it lower the cpu will go lower also because the air around the heatsink is cooler
my temps are as fallows
35 cpu
28 sys
32 pwm
