Are these temps ok?
bubbles
I just built my first Quad Core and I'm wondering about the temps. I am using a Lian-Li PC-A05 and a Ninja Mini with stock fan. The fan only had room to mount on the wrong side so I have it sucking air through the heatsink instead of blowing air, in order to maintain the same airflow as the case fans. The temp doesn't seem to go up much when I am gaming. I am running everything at stock speeds.
Specs:
q6600
Ninja Mini
8800GT 512mb
Abit IP35-E
4GB A-data ram
Temps at idle:
Processor seems fine on the temps, the videocard is a little higher then my msi with a zalman cooler but it is still way under the safe maximum nvidia says it can handle.
Idle temps matter little (yours look fine BTW) what's it run under 100% load......
I'm not sure how to test at 100%, but while I'm playing COD4 the GPU gets up to 74 C and the CPU gets to 60C.
I have the two 120mm case fans going but airflow of this pc-a05 case doesn't seem to reach the video card too good.
Those temps are low in comparison but prime will really let you know where you are at especially small FFT's
