Are these parts compatible?
infin|ty
AMD Athlon XP Barton 2500+
Antec ARIA Aluminum MicroATX Cube Case with 300W Power Supply, Model "LS-968(ARIA)" -RETAIL
Shuttle Motherboard for AMD processors Micro ATX, Model MN31N
ATI RADEON 9200 Video Card, 128MB DDR, 128-bit, TV-Out, 8X AGP -RETAIL
Lite-On 16X DVD-ROM, Model SOHD-167T Black, RETAIL
Kingston PC-2700 512MB OEM
Western Digital 40Gig 72000rpm IDE OEM
Vantec "Copper X" Copper CPU Cooler for Socket A/ 370, Model "CCK-6040" -RETAIL
And if im correct that is everything you need for a new computer.
I saw the deal for the microatx and realized I already had the HD, CPU, and ram. The case comes with a PSU and all I needed was the Video card and a DVD-ROM. I have XP Home already as well.
Will all those parts fit into the case and are they compatable with the micro ATX mobo I got?
Total of what I need to buy: $263.48
i dont see a problem with any of that
/edit: except for cooling. needs some kind of HSF, probabily wont come with 80mm case fans either
They all should fit in.
And yeah, thats everything you need for a computer.
How do you think it should perform. I think it shouldnt perform too bad. The video card is pretty suxx0r but I can prolly run Counter-strike 60 frames.
Just want to try a micro ATX out and alittle project to get me into my main rig build soon.
Is that a real 9200 or is it the se? If its the real 9200, can you fit a better card in there and go for a slower processor?
I'm going to get a 9500pro Referbished instead of the 9200 and keep the barton 2500+
