Are these LCDs right for me?
Devnull
I am looking for a 17-19" LCD, for under $300... I need one that is good for gaming, as its all I ever use my comp for and my video card has DVI so that would be nice. I currently have a 15" viewsonic monitor I've had since I bought it with my voodoo2 card :p I was considering a 19" CRT until I realized how cheap LCDs are getting and less space/less heat would be nice.
I am looking on newegg:
http://www.newegg.com/Product/Product.asp?Item=N82E16824116352
http://www.newegg.com/Product/Product.asp?Item=N82E16824001171
I don't know much about LCDs except that you want a quicker response time.
well the extra size of a 19" panel is really a nice thing when you are gaming, as it just helps you feel more immersed the experience.
Response time is important when considering a gamers TFT, and for the price range, you are really looking at the TN film market. It might be worth looking at models like the very popular Hyundai L90D+ and Samsung 913N / 930B as these uses Samsung's 8ms panel which is considered one of the best (if not the best) panels around for gaming at the moment. These are all 19" models and are widely used on these forums.
The Samsung 710N you listed is nice, using a 12ms Samsung panel which has been widely implemented in the 17" market. If i were you i would look at either the 8ms models in the 19" range, or the 12ms models in the 17" range (as the panels are VERY similar, and pretty much the same thing, just different sizes). Models in the 17" market to consider would probably include Samsung 172X, 710N, Hyundai Q17+. Also there's a few 12ms LG models which are very comparable in performance to the 12ms Samsung panel models. Perhaps look at the LG1780U, LG1750H for example
im uk based, so not 100% sure what the models available over there are, but basically 12ms 17" models and 8ms 19" models :D
hth
