or maybe you should install it correctly
when I installed Xonar it gave me a problem on startup with clash of drivers from Xonar and Realtek audio drivers so I disabled realtek drivers.. Is this linked to these..
well, it's better to uninstall previous drivers before putting the new sound card, so there are no conflicts.
also try reinstalling your chipset drivers
from the mobo?
will it change any programs or anything i have installed or will it just affect the drivers?
could this be causing system latency?
I won't need the audio drivers though will I? I using a Xonar soundcard instead of onboard audio..
you won't need the on-board audio drivers (Realtek), you will need the Xonar drivers though
Hey, ASIO.. wtf?
Is it in effect constantly, or something I need to enable?
Sorry, talking about ASIO (audio streaming input/output) on Xonar D2x..
Thanks for ye help ieSLIe and Joseph
:Luca
fixed
arrr matey![]()
