Are these good temps?
P
PRCop
Guest
Hello all,
I live in Puerto Rico and right now, the temperature outside is 91F and very humid. Ok, I have a Athlon 64 3700+ "San Diego" running on an ASUS A8N-SLI. It's not overclocked yet because I want to make sure the cooling is good before starting to overclock this baby.
Here are my average idle temps (Prime95 - full load temps are within parenthesis):
Daytime no AC: CPU/MOBO = 34C/34C (40C/34C)
Daytime w/AC: CPU/MOBO = 29C/29C (35C/29C)
Nighttime no AC: CPU/MOBO = 31C/31C (37C/37C)
Nighttime w/AC: CPU/MOBO = 27C/27C (33C/27C)
Are these temps good? Am I good to go, to start overclocking?
The cpu is being cooled with a ThermalTake Tornado which has 6 heatpipes and a 120mm fan. The case is a CoolerMaster Wave which has (2) 80mm intake fans in the front, and (3) exhaust fans. Of the 3 exhaust fans, two are 80mm fans mounted on the rear and top, and one 120mm fan mounted on the side panel blowing straight into the PCI-E cards.
Thanks for any feedback.
________________________
AMD Athlon 64 3700+ "San Diego"
ASUS A8N-SLI Deluxe mobo
1GB (2x512mb) Crucial Ballistix PC3200
Leadtek GeForce 6800GT TDH 256MB PCI-E
Western Digital 74GB Raptor 10,000RPM SATA HDD
Western Digital 200GB 7,200RPM SATA HDD
SoundBlaster Audigy 2 ZS soundcard
Sony Dual Layer 16X DVD-RW
Windows XP PRO
CoolerMaster Wave Midtower case
ThermalTake Tornado CPU cooler w/120mm fan
ThermalTake PurePower 680W W0049 PSU
Of course you can start overclocking, BUT you will be limited to how far you can OC compared to say, people in colder areas. It all depends on how high of temps you want in the end.
good luck
Thanks for your reply. I have another question. After much trial and error, I finally have a stable system with the following specs:
Core Speed: 2809.5 mhz
Multiplier: 10x
HTT: 280.9 mhz
Vcore: 1.475v
Memory frequency: 234.1 mhz
FSB:DRAM - CPU/12
Latencies: 2.5-3-3-6
Prime95 and MemTest COMPLETELY STABLE.
My question has to do with the temperature differential between idle and full load for the CPU.
With the above specs:
IDLE CPU temp: 29C
IDLE CASE temp: 25C
FULL LOAD CPU temp: 42C
FULL LOAD CASE temp: 26C
As you can see, under full load, the cpu temp increases by 13C degrees. Is this raise normal or should I get a faster fan for my cpu?
___________________________
Windows XP PRO
Nothing to worry about there at all. Those are still some great load temps, and all on only 1.47vcore. Good job.
