Are these good tempatures?
dunkindan
check out my temps are they any good?
Is the CPU temp when it's idle or under full load? For idle, not really great. For full load, good, could be a little better.
Wrong forum bud, this should be in teh O/C and cooling forum for the future. There's a sticky in there about temps. And those temps are a bit high. What do ya have for a cooling setup? Are you O/Cing?
[EDIT] i guess i missed the move by about 2 seconds:D
im not overclocking, those are just running IE. I have a thermaltake copper heatsink, i have a shitty case, and 3 case fans.
There not bad but they could be lower. As long as the system is stable and not crashing on you then your temps are probably fine. I know I have a xp 1600 that runs at 51C all the time and its rock solid.
Yea mines solid as well, i think my heatsink was like an slk-6 or somehting like that. I was just wanting my computer to be alive as long as possible.
