Are these for overclocking? /confused
earthscore
I think i installed an Oc'ing driver for my 3dfx voodoo 3000 card, here are the options it gives me:
Selection:
Desktop
Direct3D
Glide / Open GL
Video Overlay
It is currently on desktop, when i put it on Direct3D it gives me two open fields, Alpha Blending and Video Dispplay.
Alpha blending can be: sharper or smoother(right now its on automatic)
Video Display can be normal or high(right now its on automatic)
When i click on Glide / Open GL i get the choices of the last one, as well as check boxes for:
Disable the splash screen
Force mipmap dithering
Limit texture memory to 2mb
Force triple buffering
When i have video overlay on i get no extra options.. I want the best performance out of my 16 mb card! so what should i do
no, none of those are for overclocking, just for settings.. overclocking involves rasing the core and memory speeds on the card, and for a voodoo, i have no idea what you would use...
if you dont have anything else, why not just plop down 30 bucks for a geforce 4 mx or something? even a that, a geforce2 class card, would rape your v3...
oh, and why the hell are you using ME over 98se?
can't buy anything, absoloutely no money at all..... is there a type of program i could use to lightly oc the card? cuz the comp im on is pretty bad and has barely sufficient cooling.....
for voodoo cards, i have no idea.. i was about 11 when voodoos were the hot item
if system cooling sucks, i do not suggest overclocking anything.
