Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Well, technically, the Iwill ZMAX-DP, which supports two Opteron processors, can probably support your FX. You should check with Iwill before buying, but it's a great SFF system.
