Are there any monitors between 60hz / 120hz?
mejobloggs
At the moment my eye is on Dell U2715 as 27" 1440p IPS is the perfect monitor for me.
I'm not fussed about 120/144hz as they take more grunt to drive, and are more expensive. However, it would be nice to get something above 60hz
Are there any monitors that are between 75-90hz or something like that??
The Korean monitoring (My Qnix) will hit between 96-120 depending on the monitor.
I know some monitor's can do 75hz. And some even overclock.
Thats about all I know that is in between.
The Crossover 2795QHD (more info) is the only overclock-able 27" 1440p monitor which truly benefits from overclocking since the Qnix/X-Star PLS now use pathetically low PWM (Side Effects) which ruins motion clarity. Overlord sells glossy overclock-albe 27" 1440p IPS, but they are sold out. The True 10 Qnix/X-Star 27" 1440p AHVA monitors are the only multi-input 27" 1440p monitors which can overclock without dropping frames, but they also use PWM.
