-Metachronos-
- Dec 15, 2005
From reading this and a few other forums, I've gotten the impression that TECs really don't cool that great. Can someone tell me otherwise?
-Metachronos- said:From reading this and a few other forums, I've gotten the impression that TECs really don't cool that great. Can someone tell me otherwise?
DFI Daishi said:the thermal conductivity across a pelt with no load across the terminals is also not too bad, meaning that you're temps won't shoot up much faster than other potential cooling failures would account for.
i fully argee with what you have said, as stated.zer0signal667 said:Each side of the peltier is a ceramic plate... what's the range of thermal conductivity that you consider "not too bad"? Most ceramics, including what these are most likely made of, are considered bad thermal conductors. "Good" thermal conductivity for a ceramic material isn't even close to that of aluminum.
first off, you're comparing apples and oranges: AS ceramique is a thermal compound, and that's all that it has to do.x_dreamer said:well, how about the artic silver ceramic....... sure its not as good as metal, but it still works decently.
DFI Daishi said:i fully argee with what you have said, as stated.
however, based on some "not so precise" testing that i did with a dead pelt, a soldering iron, a chunk of copper with a hole in it and a compunurse probe: although the CPU may get too hot to be stable when overclocked, several minutes after a failure, the proc is unlikely to jump into the "kill" zone before the motherboard is able to shut the proc down. with a heat load of 80 watts from the soldering iron, applied to a 9 cm^2 area of the pelt, it took about 3 minutes for the compunurse to start reading temps of 65C at the edge of the copper block. that's with the other side of the pelt not being cooled by anything other than an Al heatsink i had it pressed against with no thermal compound and the fan off.
it's not a precise test or anything, but it did confirm for me what some users over at XS had commented on anecdotally: even if the pelt dies and the system becomes unstable, the temps are unlikely to kill the proc, at least before the saftey shutdown triggers.
personally, i have my shut down temp set at 30C..........i'm not all that worried.
Logan321 said:"Liquid metal"? So what, use mercury as a thermal interface? lol AFAIK, that's the only metal that's liquid at room temperature... and you REALLY wouldn't want that running off your heatsink and on to surrounding conductive circuits.
Any solid metal particulate in a non-metal suspension is no different than arctic silver, in terms of how liquid the metal is. Advertizing gimic?
Logan321 said:Seriously though, I'd be worried about trace amounts being accidentally applied to other heatsinks in the computer which are made of aluminum, such as mosfets or passive northbridge heatsinks.
actually, since the heat density of the soldering iron tip is much higher than that of a proc, a better approximation still would be to sink in a temp well about .5cm horizontally away from the hole with the soldering iron in it, and vertically as close to the surface in contact with the pelt as the metal allows for.zer0signal667 said:Gotcha... so, you were heating the copper with the soldering iron, as if the copper chunk was a coldplate and the soldering iron was the CPU core? It would be more accurate to measure the temp of the soldering tip in that case. The copper chunk's temp change is going to be heavily governed by chunk geometry/interface with the heat source.
I don't mean to crap on your experiment, I like to try stuff like that too, but I wouldn't be so sure that it applies to a general situation so much as your specific system.
zer0signal667 said:I wouldn't, because I usually try to be conscious of my actions...![]()
Logan321 said:So you've never had the telltale sheen of arctic silver dusted on your finger after cleaning a heatsink while preparing for reapplication? I don't believe it.![]()
Dark_fire said:doesnt mercury have the same effect on aluminum? why not just fill your WC with mercury and pray it doest leak onto some really expensive component
Interesting. My vote is that it's simply mercury, as I know it will react with aluminum in exactly the way described in that link.Logan321 said:Fair enough. Guess I missed that... still "Please do not use any aluminium coolers!" is a warning that needs to be very carefully followed, if I recall.
http://www.frostytech.com/permalink.cfm?NewsID=46586
Who reads warning labels anyway though?![]()
Mercury in metallic form isn't terribly toxic. Not that I would advise ingesting any or breathing hot mercury fumes, but its the organic mercury compounds that are the real killers.Because mercury is highly toxic.
And what would that reaction be? Aluminum will defintily displace mecury in compounds, but elemental mercury + elemental aluminum or aluminum compounds shouldn't generate a reactionmasher said:Interesting. My vote is that it's simply mercury, as I know it will react with aluminum in exactly the way described in that link.
WRONG!Vertigo Acid said:And what would that reaction be? Aluminum will defintily displace mecury in compounds, but elemental mercury + elemental aluminum or aluminum compounds shouldn't generate a reaction
