Are refrigerators hazerdous to your PC?
larkin
Are refrigerators (minifridges) dangerous to have close to your PC or peripherals? I just layed down a whole lot of money (3k+) on a new system and in my doorm room my PC sits right next to the fridge. When the fridge compressor (or whatever it is) clicks on I can hear a slight pop in my speakers. What's this from? A guy in the doorm also has this happen to a greater extent when his fridge compressor clicks on. His speakers pop loudly and he said sometimes his joystick lights flash. He had to return the joystick and get another, which is working fine now so i dont know if that was because of the fridge. So is whatever is causing the speakers to pop, is that fanomenon bad for my system? Could it make it unstable and even worse, could it actually do damage to my electronics?
PS. I have an APC UPS that all my computer stuff is plugged into. The fridge is plugged directly in to the wall.
thanks
I really don't think so. Maybe if it is touching it parts could rattle and loosen? A fridge can put out heat, which you don't want right next to your PC. The sound from the speakers could be an electrical surge in your dorm if your neighbor has the same problem. Or possibly just RF interference?
The pop always coincides with the fridge compressor clicking on. Some electromagnetic thing it would SEEM. Although the idea that a minifridge could put out anything electronics killing is a bit silly. but why then do the speakers pop? The other dude's speakers pop and they are no where (4 feet awa) near the fridge.
Killer fridges.. WATCHOUT
An electrical surge does seem likely, with what you're describing. Normally when a fridge compressor clicks on it draws a lot of current - can be enough to make the lights in a house flicker.
I think its just cuz speakers are very sensitive, at least my altec lansing setup is. If i kick the sub wire the subwoofer outputs large amounts of static, and/or if I touch the end of the green connector the speakers make strange noises... Its probably just a split second drain in the power when the fridge kicks on and the speakers pick up on that?
I like that theory but I have the speakers connected to the UPS in the backup powered slots. So If the fridge did draw a much for a split second the UPS should compensate and continue to deliver uninterrupted power.
If you are really worried about it, and you have the option of separating them, I would do it.
Is there another place to put either one that won't be too inconvienent?
Placing the comp on the other side of the desk is not terribly inconvinient, however, the left channel speaker is about where the comp would go and it still makes a poping noise where it is. So the concern would still be there.
Ditto.
If you're really concern, get a UPS. This will smooth out the surge/spike. The worst thing that can happen is it prolly will shorten the life of the PSU without endangering the other component.
Another thing you can do is seperate the fridge from the computer's powerpoint, so at least they draw the power from different plug on the wall.
ech3lon9 said:
Ditto.
OP stated he already has the system hooked up to a UPS.
