Are my Raptors Going Extinct?
Hellsthief2.0
hey guys,
I have a abit ic7-g, p2.4c, raedon 9800, twin sticks of 128 corsair ddr and 2 36k raptors on raid 0. Now i have been having the problem reacurring for awhile now over several years. what happens is all of a sudden my computer will not load windows. it will post to the "verifying DMI..." then go black like the windos screen is gunna pop up then it just reboots itself. In the past i have had clicking sounds come from my drives like they are rebooting themselves randomly. Its almost as if when its time to load windows the HD's just reboot themselves instead. Now in the past this has always been fixed by reloading windows, and im sure it would work now. But im sick of lossing all my data so i wanna see if there is a more perminent fix for this that i can apply. Thx for your time and brain storming!
I would start by running a check disk and see if it does anything. Have you ran any diagnostics in the past when they failed? Otherwise if you do end up reformatting maybe stay away from the raid or pick up an 80gb for a backup drive so you dont lose as much if it happens frequently?
i just ran WD lifeguard on both drive nothig physical seems to be wrong with them. Right b4 this happened yesterday i remeber windows running funny and laging and crashing and i got a error windows wanted me to report right b4 it crash "SLL" or SCH" somthing like that ill search around on the web for those prefixes, maby its somthing corrupt in my windows copy
i wanna try and use a boot disk to see if i can get past the issue, since there are no hardware issues, i dont know if i need to do anyhthing special with a boot disk when using it on a raid 0 system if anyone knows let me know i havent made one b4 so gunna go do som research online about it.
just because bad mem can cause all kinds of random issues, I would suggest running memtest for at least 24 hours to rule that out.
Hell, I just fixed a server today that would reboot itself as soon as it went to boot from the C:
Turns out it was bad RAM, I yanked it out and the server booted just fine.
