Okay, so I'm running an Antec Truepower Neo 650. I'm getting a new video card tomorrow that requires an 8 pin connector, and I've only currently got 2 6 pin connectors connected to my power supply. Now... I forget exactly where I put the extra cables for my Antec power supply, but I found a different batch of spare cables from another power supply. Probably a Corsair 520HX although I'm not sure.
Basically, modular cables are all just some copper in an insulator, right? A corsair 8 pin PCI-E cable should work fine in an Antec PSU? I mean, as long as the connector fits on the actual PSU unit itself (IIRC the actual configuration of the part that plugs into the PSU can vary, sometimes 4x2 pins, sometimes a flat 8 pins)
Also, this cable has a set of 6+2 pins and 6 pin connectors on the same cable. Can I use them both for the same card, with the 6+2 pin in the middle, branching out to a 6 pin on the end? That is... they're designed to be able to power two power connectors from one cable, right?
