just curious
i'm seeing more and more PSU's (higher wattage ones) staying with the non modular design and going back to 2 rails (my PC&C 750 silencer for example), is this on purpose?
There is some bad and incorrect info floating around about modular PSUs. There is nothing wrong with a quality modular PSU in spite of what some might say.
Only thing is, single rail doesn't meet SLI spex does it?![]()
So manufacturers who do not build modular PSUs got this bad information?
Single rail PSUs are SLI/Crossfire Cerified for example: PCP&C 1KW SR, I'd pick large single rail PSUs over multi-rails PSUs for heavy overclocking on CPU and GPU
I cannot say why certain manufacturers do or do not build modular PSUs.
Can you provide an example of these rumors and explain why they are not valid?
There aren't really any rumors, there's just some comments made by a few manufacturers as to why modular is not as good as non-modular, or vice versa. The resistance difference is negligible, in our original tests, and while you lose a very small amount of efficiency, the trade-off for having modular cables makes more of a difference to most consumers.
As for the single-rail vs. multi-rail thing, it's kind of a moot point, since no PSU I know of has truly electrical independent +12V rails. They're all coming from the same source and just have different physical routes to spread out the resistance, with each route having it's own OCP point so that there's never any serious danger due to overheating cables and all that. That's how multiple rail PSUs seem to work now, or at least how ours works.
This means that although the official spec says 18A each on all 3 +12V rails, what it's supposed to be saying is that the OCP point on each rail is 18A. In reality, that's been raised considerably to allow high-powered GPUs to take advantage of the power they need. With a single 8800GTX taking ~14A at full load, if you put one of those cards on the same rail as a couple of hard drives you could overload it at 18A. So the OCP point was raised much higher.
The reason it's still spec'd that way is due to some complicated issues with ATX 2.2 compliance and our label and box orders back when we designed the product. The product itself never shipped with actual 18A OCP limits on the +12V rails, to my knowledge, since the ATX 2.4 spec allowed us to modify that.
snip
Yeah...we all know...you keep posting that marketing page and like last time it is still misleading.
One - I dont work for any computer company I work in the dull banking world.
Two - I wasted some money on new "hyped" cpus and couldnt overclock it at all...plus other stupid investments like SLI.
Three - just trying to help others avoid makin same costly mistakes Ive made in the past.
Four - Isnt that what this forum is all about to take into account all points of view?
The problem with this thread is that its all one-sided. Just trying to add to the options.
I have a hard time with your comments in that your going up against PC Power and Cooling. Where are your facts? PC Power and Cooling is always been the standard to judge other psus...also the most expensive. They have also been making multirail psus for quite some time. Why the sudden shift?
Here is the issue. Is PC Power and Cooling just trying to shift back into a less costly design to sell more of their psus or are they simply stating fact?
Here are the facts: A large, single 12-volt rail (without a 240VA limit) can transfer 100% of the 12-volt output from the PSU to the computer
This is only true if that rail ONLY provides power to that specific area and if the other rails are limited to providing their "rated" spec. However, I don't know of a single power supply where the 4/8-pin PSU connector is its own separate rail. Not a single one. So in this mythical, bizarro-world PSU that PC Power & Cooling is talking about, they could be right.while a multi-rail 12-volt design has distribution losses of up to 30% of the power supplys rating. Those losses occur because power literally gets trapped on under-utilized rails. For example, if the 12-volt rail that powers the CPU is rated for 17 amps and the CPU only uses 7A, the remaining 10A is unusable, since it is isolated from the rest of the system.
Since the maximum current from any one 12-volt rail of a multiple-rail PSU is limited to 20 amps (240VA / 12 volts = 20 amps), PCs with high-performance components that draw over 20 amps from the same rail are subject to over-current shutdowns.
With power requirements for multiple processors and graphics cards continuing to grow, the multiple-rail design, with its 240VA limit per rail, is basically obsolete.
PC Power and Cooling is once again leading the industry. All of our power supplies now feature a large, single 12-volt rail. The design is favored by major processor and graphics companies, complies with EPS12V specs (the 240VA limit is not a requirement) and is approved by all major safety agencies such as UL and TUV.
just curious
you mean single rail right? I'd pick 4 rails over 2 rails PSUs, as far as your concerned modular PSUs are the same like other PSUs, you can have your normal PSUs converted to modular PSUs like PCP&C can have their normal PSUs converted to modular requested by customer, modular PSUs aren't dying since it always come later in time!
In your opinion John is there there any appreciable difference in quality and performance between a $200 PC&C 500 watter and the Seasonic SS-500HT that I can get for 99 bucks? Not that I would spend 99 mind you because my needs are met by the "free after rebate" 500W Ultra V-series.
But I tend to agree with you there is a whole lot of marketing department BS in the power supply game, over trying to turn a power supply which is a commodity item, into a boutique object like it's a Rolex watch or something. I understand that higher quality components cost more and tighter tolerances cost more, and I understand thermal efficiency costs more up front but you recoup some later on the electric bill.
And if power supply A fluctuates by +/- 0.2 on the 12V and power supply B only is +/- .05 V for example does even that necessarily make a difference? Or does it even make a difference by the time to it gets to my motherboard that has 6 phase voltage regulator on the board? Because based on my experience with the Ultra V-Series I am overclocking to the bleeding edge of the chip where adding 1/100 of a volt causes it to reboot. Yet, as long as I do not add that final 1/100th of a volt system is stable and the results are repeatable. Power supply is not getting hot at least the exhaust air, more than about 10% of the time. So as long as the PS does not set my house on fire I am more than happy with it. You would think my Vcore would be jumping up and down all by itself but it is remarkably stable. And my GPU is not crashing either.
Anyone can see what a guy who spent $200 more than me on a vid card is gettting for his dollar, and obvious what the guy who spent $200 more on a faster CPU is getting in terms of payback. I am having trouble seeing what the guy who spends $200 more on a PS is getting though.
Thanks for the answers. I was referring to the 510W PC Power & Cooling that lists for $200. Anyway not trying to stir the pot at least not for the moment.
