are dfi mobos picky about ram?
stealthy123
or do they work fine with cheap crappy ddr as long as the ram isn't defective?
I don't wanna buy new ram but I need a new mobo and I was gonna try a dfi board this round but I don't wanna worry about anything else but replacing the mobo.
specifically I have kingmax ram that I don't wanna replace just yet.
i concur. more than slightly picky.
to be more specific, I know there are issues with Corsair. it's hard to get them working, but it's possible.
regarding "cheap, crappy ddr" I'm not exactly sure, because people just don't use cheap crappy ddr with a DFI board. it seems to defeat the purpose -- a great overclocking mobo, just so you can plug bad ram in and get horrible overclocks (if any at all)?
if you don't want to buy new ram, go with something more stable and less fickle like an ASUS motherboard.
That would probably work fine but I'd check the dfi street team board or email ocz to see how compatible.
The g. skill in my sig has the same stock timings so its probably the same exact chips. And the g. skill was cheap as hell at newegg recently, the deal might be still going.
yeah, those have been reccommended alot. But those corsairs in the link wont work with a dfi ultra nf4 infinity or a dfi ultra d?
HERE is a link to a DFI-street post that lists a lot of the RAM that is known to work well. I can personnaly say that the OCZ Gold DDR500 that someone linked worked great for me.
There dosen't appear to be any mention of Kingmax RAM though.
I tried Corsair value ram in my DFI, and it worked, but only if I lowered the speed to ~DDR 200. I replaced it with the OCZ gold, and it worked fine.
Overall, OCZ and DFI go great together. If you wish to use Corsair, here's a database of stock speeds that are known to work:
http://www.dfi-street.com/forum/showthread.php?t=25447
if yours doesn't work with that, or if it's not there, not many people can help you.
and the GSkill is probably okay. I haven't seen many complaints about that, mostly about corsair.
Until this week, when I switched to 2gb of g.skill pc4000, I was using 1gb of Corsair Value ram. Worked out of the box no problem at all.
was the switch worth it?
Do not buy a DFI motherboard if you have any intentions of using SLI or running a high quality PSU! The Expert has a design flaw that doesn't allow 600W+ PSUs to function properly and cause the system not to boot. DFI tech support are liars about the issue as well. I hope DFI goes under because they are incompetant and make poor quality motherboards.
is that only on the expert?
No if you read through the dfi-street forums it looks like all the DR LanPartys have the problem. You really have to look though because the mods skirt around the issue and move threads to sections that dont apply or simply lock the threads. DFI has a major problem on their hands, I am returning the board and will try an Asus.
the venus also has the problem.
yup, the DFI mods (especially ex-roadie) deny vehemently that the problem is with the board but at the same time in other threads they say to RMA the board and ask for the OCZ power supply 'fix'. note that the mods on DFI-street are DFI employees!
I made a comment in the 'recomended power supply' thread that they remove all the powersupplies that are having problems from the recommended list. guess what!
exroadie replied, "Then you'd be left with nothing and that wouldn't work either.
These are the best possible units for success. If you get one that won't work replace it.
As imperfect as that sounds it's our only option."
So reading between the lines it says ALL the recommended powersupplies have problems with DFI boards. :eek: How can so many PSU companies be making inferior powersupplies?
OCZ told me the DFI boards try to draw about 3.5 amps on the 5v rail during boot-up causing the power supply to go into a fault protect. most mother boards draw about 2 amps.
not ALL the expert/venus boards have problems with the PSU's but it is a high enough percentage to be worried.
jcll2002 said:
so it is or isnt safe to go with a dfi ultra d or nf4 ultra infinity?
Sure, but you need to first understand what PSU is needed.
I had an Expert (first rev. - AA0) and on the advice of RGone (a Super-Mod) at DFI Street forum chose the PSU in my sig.
It solved a "cold boot" problem on one of his boards, and I never had any kind of problem.
It only costs about $70, has modular cables, very quiet, and works great - for one vid card or reasonable SLI - maybe not two of the latest stuff.
Do go to DFI Street and do an "advanced search" under RGONE as username.
He has lots of great info about Expert/Venus PSU's - they ARE different than the other DFI boards, hence a lot of confusion about "recomended PSUs".
You will notice I'm using Kingmax TinyBGA DDR-500. It runs great in my Venus, but gave problems in my Expert.
That's kinda the way it is with DFI boards - great boards, but you have to find the quirks in YOUR particular board.
Tons of help at the Street, though. Really makes up for the occasional rough spot.
And when you visit, be sure to stop by the "Overclocking" section and download their "Overclocking Guide" in .pdf format.
You just might want to read it, too. :p
Suprising how many don't.
it seems that the expert and venus are still damn picky..
those of you who know me know how much ram i burn through.. i've never once had a problem getting ram working at stock (and pretty oc'ed speeds too) on my ultra-d unless it truely was a bum set. ;)
if anything, i'd say that if you know what you're doing, dfi's compatibility is impossible to beat. the key is that you have to understand what you're setting if the auto settings don't work too well
I guess i must be lucky getting my corsair 3500LLPRO to run on my expert and ultra-d. I have overclocked 260fsb 1:1 on both
