Resolutions
* 1680 by 1050 pixels (optimum resolution)
* 1280 by 800 pixels
* 1024 by 640 pixels
Display colors (maximum)
* 16.7 million
Viewing angle (typical)
* 170* horizontal; 170* vertical
Brightness (typical)
* 20-inch Cinema Display: 250 cd/m2
Contrast ratio (typical)
* 400:1
Response time (typical)
* 16 ms
* 400:1
Pixel pitch
* 20-inch Cinema Display: 0.258 mm
I can get it for about $700
Do you guys think this is a good monitor for gaming, i read the reviews and they claim 16ms is "lighting fast" and doesnt ghost. Also..is that contrast ratio good? Wouldnt you want it a little higher?
If this monitor isnt really up to par for gaming is there anything else you could recommend to me that is 20 inches and wide. less than or equal to $700
* 16.7 million
* 400:1
* 16 ms
* 400:1
Pixel pitch
