Gutspiller
- Oct 19, 2005
I may be looking for a new power supply shortly, but once I find out, I won't have much time to make up my mind.
I currently have a 650 Antec Trio True Power
My system specs are below:
9800GX2
E6600 (Going to be upgrading to E8400 / E8500)
2GB memory (Going to be going to 4GB soon)
Rampage Formula Mobo
X-fi Extreme Music Sound card.
3 internal hard drives (Hopeful plans of getting a VelociRaptor RAID going once released)
3 external hard drives connected through USB, though all 3 are rarely all on at the same time
WinXP with plans to go Vista after a 4GB memory upgrade
4 120mm case fans
I first want to know whether or not I'm going to buy a 1000 watt PSU and in a FEW year need soemthing with either more wattage, or different types of connectors. I don't think I need 1000watt right now, especially since my 650 is running my current setup fine, but if I have the chance to upgrade, I want to upgrade to something that will have all the connections I'm going to need for a good 3 or more years. If new connections are going to be coming out though, then I don't think I want to spring for a 1000w right now.
Lastly, I have an Antec case that really needs a normal sized power supply. I know a bunch of 1000w PSUs are longer and my case will not fit a much longer PSU. If I remember correctly, it can hold a PSU with a depth of about 6.5 inches, but any more and cables will be running into fan blades.
PSU requirements
2 6pin PCI-E powers
2 8pin PCI-E powers
1 8pin mobo power
3+ year warranty (standard?)
Depth no greater than 6 3/4 inches.
Modular
Ideas or recommendations? I'm looking to go with brand names and names that I can trust. I've already checked and Antecs 850 and 1000 watt are too long or very close.
EDIT: It looks like the cable length given with 1000w PSUs, I actually WILL need a modular PSU as the Antec case doesn't give room for a spot to hide all those cables.
9800GX2
4 120mm case fans
PSU requirements
2 6pin PCI-E powers
2 8pin PCI-E powers
1 8pin mobo power
Modular
