Arcticlean conductivity
Pilot53
Is thermal surface remover and purifier electically conductive? A tiny bit spilled off the chip onto the board, should I be concerned?
No, in fact if it's the purifier (step 2) it will evaporate completely without leaving any residue.
If you spilled the thermal compound remover (step 1) it will also evaporate rather quickly, although it may leave a slight residue. Neither step is significantly electrically conductive.
