Arctic silver or thermal pad ?
wikidlad
I bought the Arctic Cooling Freezer pro 7 and it comes with a thermal pad on it, whats better for overclocking....keeping this pad on or wiping it off and using arctic silver ?
Thanks
If you have AS5, wipe off the thermal pad and apply some. If you don't have AS5 then the thermal pad will work fine.
Get either Shin-Etsu X23 or AS MX-2 if you want new pastes. Otherwise stick with the stock it is MX1.
Whats on your Freezer Pro isn't exactly a "pad". Its actually a preapplied square of MX-1. Its good stuff. Give it a try.
