Arctic Silver for Scythe Ninja?
the worst that will happen is when you turn on your machine the temps skyrocket and it'll auto shutdown (like mine did :D because I didn't have the HS mounted correctly). No worries, just turn it off and reapply.
why dont u try the zalman thermal paste then, comes in a small bottle with a brush that similar to what u get in nail polish n its easier to apply.
beamer7296 said:
I'm still really nervous about doing this though. Is my CPU in jepardy if I use too much?
Nothing bad happened to me...
kuyaglen said:
An application like this has no benefit since the core of the CPU is the only part that can transfer heat to the heatsink. A general rule of thumb for CPUs with heatspreaders is to use enough paste to cover the surface completely or a bit before the edges. The important part is the center, but I like to cover as much of the heatspreader as possible since it does help a little with heat transfer.
That's exactly what I'm using. I was VERY pleasantly surprised to see temps drop almost 20c on load, from 57-60c to 35-40c. After about 2 weeks of running more or less 12 hours on, 12 hours off (with the exception of over thanksgiving, when I was out of town and it was off), the AC5 has cured nicely, with a drop of an additional 5c(ish). Very nice. I can't sing its praises enough.
I love you, Scythe Ninja. :)
