Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
well bought some arctic silver 5 and put it on my barton 2500 but my temps didnt go down, im still at 35 degrees celcius with slk800 and a vantec tornado 80 mm, what is wrong?? and should i put some silver on my vid card
your cpu temp doesn't seem that high, but check the arctic silver site to make sure you applied it properly. About the video card, i think you need the epoxy for that, but i'm not sure.
