malicious said:whichever you use .. it's not as good as direct metal contact so use a little as possible
no, you *definitely* need the paste. ideally, direct metal contact would be best, but the metals arent perfectly smooth, so there'd be gaps. that's what the paste is for; it fills in the gaps. that's why you want as thin a layer as possible, so it doesnt cover up where the metal could be going metal to metal, but it fills in all the tiny spaces where metal doesnt touch.The_Law said:So is it better to go without? Should I just put my HS directly on the chip w/o paste? If it is better without, what is the point of the paste? Sorry for all the newb questions, I am really getting into the nuts and bolts of things for the first time.
I second that, by all means DO NOT neglect to use conductive material, or bye-bye CPU.Soymilk said:no, you *definitely* need the paste. ideally, direct metal contact would be best, but the metals arent perfectly smooth, so there'd be gaps. that's what the paste is for; it fills in the gaps. that's why you want as thin a layer as possible, so it doesnt cover up where the metal could be going metal to metal, but it fills in all the tiny spaces where metal doesnt touch.
iSkylla said:lap the CPU core
Not Electrically Conductive:
Arctic Silver 5 was formulated to conduct heat, not electricity.
(While much safer than electrically conductive silver and copper greases, Arctic Silver 5 should be kept away from electrical traces, pins, and leads. While it is not electrically conductive, the compound is very slightly capacitive and could potentially cause problems if it bridges two close-proximity electrical paths.)
pstang said:i prefer using AS5 myself
why does everyone think AS5 eletrically conductive?
http://www.arcticsilver.com/as5.htm
besides this stuff goes on IHS, HSF and cores.... you aren't supposed to be sloping it all over the place... remember the "more is better" does not apply to thermal interface material
quoted for mega fucking truth
I thought with the socket 939's u didnt have to speread it out, just put a small amount on the IHS?
cornelious0_0 said:Please watch your language...this is an all ages forum and I know for a fact that profanity isn't tolerated...check the forum rules.
ScHpAnKy said:(7) No CUSSING in the thread title. It is permitted in the thread body, but please refrain from using excessive profanity dammit.
Uh-oh, it's permitted!
the middle dab method works because you really only need the compound covering the area where the actual core is. there shouldnt be a difference between the dab method and making a thin layer, provided that they're both done correctly, or if there is, it's insignificant (like 1C or some crap like that)cornelious0_0 said:For many people that does work...I've only tried the "middle dab" method once...can't say it drastically hurt my temps...but using the rice grain sized portion that is mentioned isn't enough to cover the full surface area of a full sized IHS. i start with a small dab of that size, but spread it one way or another to create a paper thin layer over the total surface of the IHS...the dab method works very well for smaller surfaces...ie: AXP's that have no IHS.
Soymilk said:the middle dab method works because you really only need the compound covering the area where the actual core is. there shouldnt be a difference between the dab method and making a thin layer, provided that they're both done correctly, or if there is, it's insignificant (like 1C or some crap like that)
Soymilk said:what were ur temps before using the new stuff? were u using as5?
2Fresh said:i have used AS5 and Ceramique..cant tell a diff. Using Ceramique now.
It will make a big difference for extreme cooling @ <-50C..Double Jesus said:<3 these threads... it really doesn't matter THAT much which you use. as a few have stated in this thread, they don't notice a difference and according to dan at dansdata there's no real noticeable difference. the article compares a pile of different tims, he even tried toothpaste and vegemite. nice read up on the way some people use graphs as well, i thought that was pretty funny.
centvalny said:It will make a big difference for extreme cooling @ <-50C..
@ near ambient temp. ...yes, there almost no difference.
