DarkStar02
- Mar 1, 2006
I ordered the Freezer 7 pro and it came with a dead heatsink. I have some 120mm fans and I'm thinking about just gluing a 120mm fan on there instead of just waiting for the RMA from newegg. Would this be a good idea? The thermaltake fan is controllable also so I could turn the knob that drops in the PCI slot and adjust the fan speed when overclocking. Would the 120mm fan hurt or help for performance? Also, would krazy glue be adequate for holding the fan on?
