Arctic cooling nv5 rev.2
Where can I buy a Arctic cooling nv5 rev.2 in the UK?
I want this one as it provides a replacement pci bracket which is single slot, so that I can exhaust the air on my ultra...
Failing that, is there anywhere in the UK that I can order replacement single slot pci brackets for a 6800 ultra (I.E. from dual to single, with all the right holes for dvi etc...)?
thanks
f
